EEPROM
but that is the problem .....i got a colegue in my clsass that i thing he can do that in about 10-20 seconds...and he is no genius and he wasnt born with this ability, he just trained....
thats true....speed matters, but the brain is used only a little, if you train you can do better and better
ok, now back to EPROMs i got some old EPROMs wich i wana use for controlling some leds, but the problem is programming...is there a VERY simple programmer for 2716 to 27512? i mean a programmer with little components and easy to find? i searched the internet but i couldnt find what i need. the problem was that they were quite simple but i couldnt find those ICs needed for it.
arcom said:
Here is a quick calculation of my own :D :
1 GB = 1073741824 bytes (note: use 1 byte for 1 sequence)
Provided that you display each sequence every 0.5 seconds, you can store up to 536870912 seconds of "animation". If you convert this to hours (better to years, lol), you get the following:
34,05 years of animated sequences :lol: :lol: :lol:
The calculations you have done are correct but when I mentioned 1Gb meant 1 GIGA-BIT and not Giga-Byte :) So your time will reduce to about 8 times since 8-bits = 1 byte.
ok, about that link on EPROMs, it looks like quite a simple programmer on second thought, but i cant find replacements for the MPSA65 transistors...any ideas?
and the ones labbeled 558 and 548 are BC558 and BC548?
I thought so. One gigabyte is written in capital letters. Silly me. Well, nevermind, that still leaves 4,25 years :)
Yes they are BC558 and BC548. As I said in other post, I am not able to locte my transistor selector book so I can't find exact replacement for MPSA65.
Found my yellow book:
mps-a 65:
Si-P-Darl Uni,30V,0.3A,0.625W B>50000
_____
|_______|
C B E
replacement bc 880:
Si-P-Darl 100V,1A,0.8W,200MHzb>2000
Low frequency switch
_____
|_______|
B C E
