What are the highest and lowest temperatures you can apply? Going down to absolute zero would probably do it .what is the best temperature cycle to crack a eutectic solder?
?? Are you trying to detect a defective solder joint inside a diode, or between a diode leg and some other circuit part?if im using diode, the how cn we know?
Then the fact that it's a diode makes no difference. Try a DMM on the Ohms range, with probes on that leg and the pcb.between a diode leg and pcb
I don't have the slightest idea what you're on about?, there's no relation between dry joints and bias?.
good idea..but will it affect the solder performance?Cracks in solder joints show up real easy using freeze spray.
