Hi guys,
I hv found that at that low duty cycle and so high an input voltage, design is messy. Hence I hv opted for a lower voltage solar array. I am fabricating the prototype as follows, -
I/p voltage - 81 Volts peak, that is six 170 Wp modules, connected three in series, two strings in parallel, total 1020 Wp, Vmax - 72 Volts, Imax - 14.18 Amps.
Battery bank - 4 x 12v/180 ah batteries in series. Nominal voltage - 48 Volts, peak charging voltage - 64 volts, minimum duty ratio - 0.61.
I am using two buck converters interleaved. As for push - pull or other isolated topologies, an extra magnetic element (assuming the switching and conduction losses of the single switch and diode of the buck converter is equally distributed in the two switches and two diodes of these topologies) should add extra losses. However, doing is believing. First I will go with this prototype (there is no turning back, as I hv already fabricated the control and drive card). Then we shall look into the alternatives.
Anyway, Thanks again for all the suggestions.
