chemelec
Dr.EM said:I also read the tantalum comes from a Gorilla habitat and that it is damaging that habitat by us taking it?
I Really Don't belive that statement.
chemelec said:I Really Don't belive that statement.
Sceadwian said:Nigel, you keep stateing that tantalum's are very unreliable or have been in the past, what are the failure mode's they're known for, and specifically why do they fail?
Nigel Goodwin said:I don't know if people here remember the valve days?, but a common capacitor manufacturer was Wima (non-electrolytics) - and those were also extremely unreliable. To the extent that if you ever saw them used in a piece of equipment for repair, the first thing you did was replace them all - and that would cure 90%+ of the faults. Tantalums aren't quite that bad, but if you see any on a board the first thing you do is check them all to see if they are S/C - this finds the majority of faults (or did, back when they were used!).
eng1 said:On regulated lines the failure rate increases because of the low output impedance of IC regulators. In those applications the operating voltage should be much less than the rated one.
Nigel Goodwin said:This was pre-IC regulators - but in any case that doesn't make much sense?.
eng1 said:Some app notes suggest that the operating voltage should be 30% of the rated one, when tantalum caps are used with regulated power supplies. If the output voltage is 12 V or more, 36 V rated tantalum caps are expensive. And aluminum electrolytic technology has improved... they fearure low ESR as well and higher voltages.
eng1 said:![]()
Nigel, I think that you'll never choose tantalum capacitors!?!
chemelec said:Nigel Goodwin, Since your mostly opposed to Tantalums,
Nigel Goodwin said:I've never seen any reason to trust them?, and the lack of them now in anything I ever see seems to prove me right. Perhaps tantalums are more reliable now?, but domestic electronics manufacturers don't seem to be convinced after the previous disasters!.
I'm also somewhat dubious about using components with have a specific rating, then a warning in the datasheet not to exceed 1/3 of that rating - it seems a poor way to specify a component!.
Personally, I use aluminum type at the input because they're cheaper and low ESR is required at the output to avoid oscillation.Optikon said:Actually, this problem is not as bad when they are on the outputs of IC regulators. A much worse scenario exists when they are on the "input" side. This side _usually_ connect to an even lower impedance source and the startup surge current often does these caps in.
Good observation!Optikon said:IC regulators usually have current limit built into them and I often wonder if this is responsible for output tantalums surviving repeated startup surge currents.
Optikon said:When was the last time you saw an aluminum electrolytic datasheet that read:
CAUTION: The electrolyte in this capacitor will dry out over time and cause the component to fail. It will likely be the most unreliable part in your design. Please de-rate generously to imporve longevity. Enjoy!
