Frosty_47
I want to build electronic dead bolt that locks via actuator. The bolt will be attached to the outside of the door on the inside of the apartment (not inside the door like conventional dead bolts). Electronic controlled actuator will slide the bolt in and out of the bracket that will be attached to the door frame. The whole system can only be activated by a wireless remote, so there will be no visible keypads or scanners on the outside of the door.
The problem I have is zero experience with wireless transmitters. I built simple AM, FM circuits but that's about it. Any suggestions on what to use to built a wireless remote? Perhaps I can use infrared by putting a small infrared receiver through the door?
-Thanks
-Thanks
