Error[113] C:\PROJECTS\PIC\TEST\LESSON4A\LESSON4.ASM 4 : Symbol not previously defi
As Diver points out you should have an appropriate Header to your program.
There is no need to change the Radix, if you use .5 thats 5 decimal,
0xFF 0FFh and .255 are the same value.
This is an example.
         list      p=16F84A            ; list directive to define processor
	#include <p16F84A.inc>        ; processor specific variable definitions
	errorlevel -302, -207
	__CONFIG   _CP_OFF & _WDT_OFF & _PWRTE_ON & _XT_OSC
		ORG     0x000             ; processor reset vector
  		goto    main              ; go to beginning of program
		ORG     0x004             ; interrupt vector location
		nop
		retfie                    ; return from interrupt
main:
;your code goes here.
     movlw .5
     clrw
     nop
     end
Diver300 introducing the 'org 0x00' work fine whilst maintaining the first code. below is the initial code thanks guys for the assist. Final working code is below for reference:
processor 16f84a
include <p16f84a.inc>
__config _HS_OSC & _WDT_OFF & _PWRTE_ON
org 0x00
movlw D'5'
clrw
nop
end
