JJGross said:I've also found that you can do a clean (and very cheap) toner transfer using the backing paper from stickers. I used the backing sheets from CD labels since they're full letter sized and don't jam up my old HP laser printer I got @ Goodwill for $10.
I was using old band advertising slicks (8x10 glossy thin paper) and got really good results, but the slightly waxy but thick sticker backing is the schnitz.
Cheers!
There are two things you need in a paper. It needs to hold the toner well enough to keep it from moving or falling off during the process. It also need to release the toner after fusing to the copper.
Cooking parchment and ALU foil do not hold the toner well enough.
The mailing label backing paper I tried was too loose but usable if one was careful.
Most other papers allow the toner to soak into the paper fibers. No problem holding the image but a bear to remove the paper.
The starch is a very good idea because it holds the toner well when dry and releases it 100% when wet.
