throbscottle
There are loads of buck converter modules on eBay sold as KIS3R33 (as one vendor says "not new, take apart from machine") so I bought a dozen to play with since they look like a good way to replace linear regulators (actually going to use one in Roman's small capacitance meter, woo hoo!)
They contain an MP2307 buck converter with support components, and output a nominal 3.3v. Loads of people are selling kits to convert them to a variable psu.
I read about buck-boost converters recently, and wanted to see if I could modify one of these modules to produce a negative voltage.
Original output was 2.29v I think.
The modification was very easy. First pop open the case. Cut a couple of vias using a drill bit to disconnect the input capacitor (10uF ceramic) from the ground plane. Connect what used to be the module's output to the capacitor I just disconnected. This then becomes ground. The input stays the same, the original ground now becomes the negative output.
Switch on and hide under the bench...
Output only read -0.22v, so I connected an extra capacitor across it, trying not to be confused about the polarity. Output went down to -3.31v. Connected a 200Ω resistor, voltage went to -3.3v.
Well, I need to play with it some more, but this looks like a great cheap way to get a negative output from a single supply.
Next experiment is strapping a couple of these in parallel to increase the available current. I'm guessing they need to share a single feedback network to do this, possibly also a series resistor with each inductor. Also want to see if I can make negative and positive adjustable tracking outputs.
