list p=18F1320
include <p18F1320.inc>
CONFIG OSC=INTIO2,WDT=OFF,MCLRE=ON,LVP=OFF
cblock 0x00
datatmp
d1
d2
d3
endc
SDA2 Equ 3
SCL2 Equ 2
org 0x0000
init
bsf OSCCON,IRCF2 ;set to 8MHz clock
bsf OSCCON,IRCF1
bsf OSCCON,IRCF0
call I2C_TestWrite
main
goto main
I2C_TestWrite
call I2C_Start
call Delay5us
movlw 0xA0
call I2C_SendByte
call Delay5us
movlw 0x00
call I2C_SendByte
call Delay5us
movlw 0x0F
call I2C_SendByte
call Delay5us
call I2C_Stop
call Delay5us
return
I2C_Start
clrf TRISB
clrf PORTB
BSF PORTB, SDA2
BSF PORTB, SCL2
call Delay5us
BCF PORTB, SDA2
call Delay5us
BCF PORTB, SCL2
call Delay5us
BSF TRISB, SDA2
return
I2C_Stop
BSF TRISB, SDA2
BCF PORTB, SDA2
call Delay5us
BSF PORTB, SCL2
call Delay5us
BSF PORTB, SDA2
call Delay5us
BCF TRISB, SDA2
return
I2C_SendByte
movwf datatmp
movlw 0x08
Loop_X
btfss datatmp, 0
call I2C_Send0
btfsc datatmp, 0
call I2C_Send1
RLNCF datatmp
DECFSZ W
goto Loop_X
return
I2C_Send1
bcf TRISB, SDA2
bsf PORTB, SDA2
call Delay5us
bsf PORTB, SCL2
call Delay5us
bcf PORTB, SCL2
call Delay5us
bsf TRISB, SDA2
return
I2C_Send0
bcf TRISB, SDA2
bcf PORTB, SDA2
call Delay5us
bsf PORTB, SCL2
call Delay5us
bcf PORTB, SCL2
call Delay5us
bsf TRISB, SDA2
return
Delay5us
bra $+2
bra $+2
return
end
im trying to use the sourceC sample code and when i try to compile it i get tons of errors
C:\PicCode\eeprom\main.c(104:12): error: failed to parse template arguments
C:\PicCode\eeprom\main.c(111:2): error: failed to generate expression
and others but those are most common. The code is attached.
// Copyright(C) 2004-2006 Andrew Smallridge
// Copyright(C) 2004-2008 Pavel Baranov
// Copyright(C) 2004-2008 David Hobday
// Existing constants predefined for i2c hardware driver and i2s software
// emulation for the PIC 18F2xx and 18F4xx processors. For hardware support
// on other PICs the constants must be mapped to the corresponding register
// map of the target device
// variables cannot be passed as template arguments. The following constants map to
// the PIC registers and software emalated i2c RAM locations. These constants are
// then used by the templated functions. When changing the address of an emulated
// register the corresponding constant mapping must also be changed.
#if defined use_i2c_SW
// i2c software implementation template arguments and variables
#define i2c_ARGS 3, PORTC, TRISC, 4, PORTC, TRISC, e_SSPCON1, e_SSPCON2, \
e_SSPSTAT, e_SSPBUF, e_SSPIF_BIT, e_SSPIF_PIR, \
e_BCLIF_BIT, e_BCLIF_PIR, 7, e_SSPADD, (i2c_reset_wdt | i2c_SMP)
// RAM used by the software i2c driver to emulate the equivalent i2c hardware registers
unsigned short swi2c_SSPCON1@0x40; // define location for the emulated SSPCON1
unsigned short swi2c_SSPCON2@0x41; // define location for the emulated SSPCON2
unsigned short swi2c_SSPSTAT@0x42; // define location for the emulated SSPSTAT
unsigned short swi2c_SSPBUF@0x43; // define location for the emulated SSPBUF
unsigned short swi2c_SSPIF_PIR@0x44;// define location for the emulated SSPIF_PIR
unsigned short swi2c_BCLIF_PIR@0x45;// define location for the emulated BCLIF_PIR
unsigned short swi2c_SSPADD@0x46; // define location for the emulated SSPADD
#define e_SSPCON1 0x40
#define e_SSPCON2 0x41
#define e_SSPSTAT 0x42
#define e_SSPADD 0x43
#define e_SSPBUF 0x44
#define e_SSPIF_PIR 0x45
#define e_BCLIF_PIR 0x46
#define e_SSPIF_BIT 3
#define e_BCLIF_BIT 3
#define i2c_ARGS 3, PORTB, TRISB, 4, PORTB, TRISB, e_SSPCON1, e_SSPCON2, \
I2C_TestWrite
call I2C_Start
call Delay5us
movlw 0xA0
call I2C_SendByte
> ----- ACK - ninth clock mpulse
call Delay5us
movlw 0x00
call I2C_SendByte
call Delay5us
movlw 0x0F
call I2C_SendByte
call Delay5us
call I2C_Stop
call Delay5us
return
ASK check
SDA > INPUT
SCL=1
ASK check (one SCL clock mpulse where you must check SDA line for ASK)
SCL=0
SDA > OUTPUT
void i2c_init( void )
/* Initialize processor I/O pins (SDA and SCL) involved in I2C operation */
I2C_Status = 0;
/* Declare both signals output, making sure
they apply a HIGH level */
SET_SDA();
SET_SCL();
SET_SDA_TO_OUTPUT();
SET_SCL_TO_OUTPUT();
/* Check the signal levels */
if( !SCL_SET() ) I2C_Status |= I2C_SCL_STUCK_LOW;
if( !SDA_SET() ) I2C_Status |= I2C_SDA_STUCK_LOW;
#define MUS_DELAY 5
void i2c_delay( void )
/* To match the maximum bitrate we need to add some delay in places,
done here with a simple busy-wait loop; minimum delay is 3 mus;
measured for an ATmega103 running at 4 MHz */
BYTE i;
for( i=0; i<(MUS_DELAY-3); ++i );
void i2c_start( void )
/* Generate I2C START condition */
SET_SDA();
SET_SCL();
i2c_delay();
CLEAR_SDA();
i2c_delay();
CLEAR_SCL();
i2c_delay();
void i2c_stop( void )
/* Generate I2C STOP condition */
CLEAR_SDA();
SET_SCL();
i2c_delay();
SET_SDA();
i2c_delay();
void i2c_write( BYTE byt )
/* Write a byte to the I2C bus; errors are stored in I2C_Status
and can be inspected by calling i2c_status() */
BYTE i;
/* Set SDA back to output */
/* Send BYTE, MSB first */
for( i=0; i<8; ++i )
if( byt & 0x80 )
SET_SDA();
else
CLEAR_SDA();
/* Get ready for next bit */
byt <<= 1;
SET_SCL();
i2c_delay();
CLEAR_SCL();
i2c_delay();
/* To receive the acknowledge, set SDA to input (without pull-up) */
SET_SDA_TO_INPUT();
CLEAR_SDA();
/* Get the acknowledge */
SET_SCL();
i2c_delay();
CLEAR_SCL();
i2c_delay();
BYTE i2c_read( BOOLEAN last )
/* Read a byte from the I2C bus; byte value is returned;
errors are stored in I2C_Status and
can be inspected by calling i2c_status(); */
BYTE i, byt;
/* Set SDA to input, without pull-up */
SET_SDA_TO_INPUT();
CLEAR_SDA();
/* Initialize byte value */
byt = 0;
/* Receive BYTE, MSB first */
SET_SCL();
i2c_delay();
byt <<= 1;
if( SDA_SET() ) ++byt;
CLEAR_SCL();
i2c_delay();
/* Get ready for acknowledge: is it the last byte to read ? */
if( last )
SET_SDA();
else
CLEAR_SDA();
/* Set SDA to output */
SET_SCL();
i2c_delay();
CLEAR_SCL();
i2c_delay();
return byt;
BYTE i2c_status( void )
/* Return the status byte and reset it to zero */
BYTE stat;
stat = I2C_Status;
I2C_Status = 0;
return stat;
void write_eeprom(unsigned int adr)
i2c_start();
i2c_write(0xA0);
temp=adr/0xff;
i2c_write(temp);
temp=adr;
i2c_write(temp);
i2c_write(0x36);
i2c_write(0x37);
i2c_write(0x38);
i2c_stop();
delay_ms(10);
void read_eeprom(unsigned int adr)
i2c_start();
i2c_write(0xA0);
temp=adr/0xff;
i2c_write(temp);
temp=adr;
i2c_write(temp);
i2c_start();
i2c_write(0xA1);
temp= i2c_read(1);
i2c_stop();
delay_ms(1);
LIST p=16F627A ;tell assembler what chip we are using
include "P16F627A.inc" ;include the defaults for the chip
__config 0x3D18 ;sets the configuration settings (oscillator type etc.)
;***** VARIABLE DEFINITIONS
w_temp EQU 0x7E ; variable used for context saving
status_temp EQU 0x7F ; variable used for context saving
mybyte EQU 0x80
eec EQU 2
eed EQU 3
ORG 0x000 ; processor reset vector
goto main ; go to beginning of program
ORG 0x004 ; interrupt vector location
movwf w_temp ; save off current W register contents
movf STATUS,w ; move status register into W register
movwf status_temp ; save off contents of STATUS register
; isr code can go here or be located as a call subroutine elsewhere
movf status_temp,w ; retrieve copy of STATUS register
movwf STATUS ; restore pre-isr STATUS register contents
swapf w_temp,f
swapf w_temp,w ; restore pre-isr W register contents
retfie ; return from interrupt
main
movlw 0x07
movwf CMCON
bsf STATUS, RP0
clrf TRISB
clrf TRISA
bcf STATUS, RP0
clrf PORTB
clrf PORTA
;bsf PORTB, 4
;call writeit
call readit
;movf mybyte,0
;movwf PORTA
btfsc mybyte,3
bsf PORTA,3
main2
goto main2 ;loop forever, remove this instruction, for test only
readit
bsf PORTB,eed ;1 Start
call clockit
bsf PORTB,eed ;1
call clockit
bcf PORTB,eed ;0
call clockit
bsf PORTB,eed ;1
call clockit
bcf PORTB,eed ;0
call clockit
;Device Address
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
; End of device address
bcf PORTB,eed ;0 I want to write to it
call clockit
bsf STATUS, RP0
bsf TRISB,eed
bcf STATUS, RP0
call clockit
ack_04
btfsc PORTB, eed
goto ack_04
bsf STATUS, RP0
bcf TRISB,eed
bcf STATUS, RP0
;//////////////////////////// WORD ADDRESS
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bsf PORTB,eed ;1
call clockit
bsf STATUS, RP0
bsf TRISB,eed
bcf STATUS, RP0
call clockit
ack_05
btfsc PORTB, eed
goto ack_05
bsf STATUS, RP0
bcf TRISB,eed
bcf STATUS, RP0
;/////////////////////////// Random Read
call clockit
bsf PORTB,eed ;1
call clockit
bcf PORTB,eed ;0
call clockit
bsf PORTB,eed ;1
call clockit
bcf PORTB,eed ;0
call clockit
;Device Address
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bsf PORTB,eed ;1 I want to read from it
call clockit
bsf STATUS, RP0
bsf TRISB,eed
bcf STATUS, RP0
ack_06
btfsc PORTB, eed
goto ack_06
call clockit
movlw 0x08
movwf w_temp
getbits
decfsz w_temp, f
goto gotit
goto sendstop
gotit
btfsc PORTB, eed
bsf mybyte,w_temp
bcf mybyte,w_temp
call clockit
goto getbits
sendstop
bcf PORTB,eed ;0 Just in case last bit was high
call Delay5us
bsf PORTB,eec
call Delay5us
bcf PORTB,eed ;0
call Delay5us
bsf PORTB,eed ;1
call Delay5us
bcf PORTB,eec
call Delay5us
bsf PORTB, 4 ; Done!
return
return
writeit
call clockit
bsf PORTB,eed ;1
call clockit
bcf PORTB,eed ;0
call clockit
bsf PORTB,eed ;1
call clockit
bcf PORTB,eed ;0
call clockit
;Device Address
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
call clockit
bsf STATUS, RP0
bsf TRISB,eed
bcf STATUS, RP0
call clockit
ack_01
btfsc PORTB, eed
goto ack_01
bsf STATUS, RP0
bcf TRISB,eed
bcf STATUS, RP0
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bsf PORTB,eed ;1
call clockit
bsf STATUS, RP0
bsf TRISB,eed
bcf STATUS, RP0
call clockit
ack_02
btfsc PORTB, eed
goto ack_02
bsf STATUS, RP0
bcf TRISB,eed
bcf STATUS, RP0
;/////////////////////////// Data (0x08)
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bsf PORTB,eed ;1
call clockit
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bcf PORTB,eed ;0
call clockit
bsf STATUS, RP0
bsf TRISB,eed
bcf STATUS, RP0
call clockit
ack_03
btfsc PORTB, eed
goto ack_03
bsf STATUS, RP0
bcf TRISB,eed
bcf STATUS, RP0
;///////////////////////////// STOP
call Delay5us
bsf PORTB,eec
call Delay5us
bcf PORTB,eed ;0
call Delay5us
bsf PORTB,eed ;1
call Delay5us
bcf PORTB,eec
call Delay5us
return
clockit
call Delay5us
bsf PORTB,eec
call Delay5us
bcf PORTB,eec
call Delay5us
return
Delay5us
nop
return
; initialize eeprom locations
ORG 0x2100
DE 0x00, 0x01, 0x02, 0x03
END ; directive 'end of program'
Optimisation level:1
Caution: argument of 'delay_us' calls must have a value of 1 or more
Caution: Delay inaccurrate: 'delay_us', Delay overhead:0.0045ms, Unit delay:0.001ms, Delay resolution:2 units
Building CASM file
void main(void)
osccon=0x72; //8 MHz
clockt=0;
datat=0;
write_ee();
delay_s(2);
read_ee();
while(1);
and nothing works like breakpoints. BTW this is on the Junebug with 18F1320.
It skips all and goes to while(1); for some reason
Nope i still cant use a breakpoint. What version of MPLab are you using?
EDIT:
I just noticed you said simulator... It works ok in simulator but when in debugging it wont work.
