That is true. But the turn-on time for most signal diodes is quite fast and does not vary much with the fabrication process. That's why it is not generally specified.When the term "fast switching diode" is used, it refers to it's reverse recovery time and not it's turn-on time. Finding turn-on time specs for diodes isn't exactly easy.
But the turn-on time for most signal diodes is quite fast...
Yes, it's seldom mentioned. Here is an article on some forward turn-on time tests of several diodes."Quite fast" is still a relative term... how fast is "quite fast"? I've looked for spec's in the past but was unable to find any.
You likely need a Schottky diode rated for RF.I have tried 1N5819 and 1N6263 schottky diodes but none of these is working. what can be the alternative choice?
