Finding mosfet id or equivalent !
420homestead
as stated trying to find part or equivalent to the one's that are burnt for repair i see part # 21GMAA and cant find it anywhere
Why would MOSFETs be in 8-pin packages? You do know that the markings on SMD parts are shorthand codes for the actual part number – right?
It seems too long for an SMD Code and 1 has a space .. try matching dimensions to find case type and search by function like .. is it a half-bridge for 3 phase?
not sure on the half-bridge or 3 phase .. its the mosfet drivers off a 1s driven dual motor rx/esc for hobby grade ultra micro airplane.
so i have no idea of the values needed to find a acceptable replacement .. is there any way for me to test impedance/ resistance what ever needed for a more educated person in this field of expertise to find a solution .. i have multimeter and such just tell me what setting and what to touch to messure for datta needed to figure out an equivalent?
I guess that's a question for the manufacturers, since many MOSFETs are available in soic-8 packages.
I did not know that. It seems like a suboptimal choice for certain power levels.
I'd guess they are either dual MOSFETs, or "Half bridge" power driver ICs.
You need to try and trace the connections to the devices, to determine the pinout as far as possible.
eg. Which pins(s) are ground (0V, negative battery) and which are battery +?
Which connect to the output connector?
Measure the motor DCR and I would expect RdsOn around 5% of that.
If bidirectional then it is a full bridge, otherwise half bridge
e.g. https://www.digikey.ca/en/products/detail/monolithic-power-systems-inc/MP6610GJ-Z/15992058
or keep looking ... https://www.digikey.ca/en/products/...?s=N4IgTCBcDaIBYEMA2AzABAIwE4EsAmA5gKYgC6AvkA
Measure motor DCR I guess that's DC resistance that you're telling me.... and what is RDSpn what's that stand for the resistance... Okay once I have that what's that going to tell me as per after I get this measurements CR and then five find a 5% of whatever that is and then we'll kind of measurements do I do for to find House of mosfet measured
Not sure I'll what you mean it's the dual motor so there's a two sets so it's a dual ESC.../. It's on a 1S- 3.7v small plane with a dual motors
FET on resistance is RdsOn
Well my experience you know I know how to replace a solder loan component and usually I don't have much trouble finding it off the part number of the skewer at least from that I can usually get the values to find something comparable but this thing not even close that's why I need to kind of know how to testing formulate kind of what I'm looking for but I'm thinking I'm about there so I get that DC resistance and then take 5% or whatever for the flow like the other guy said and kind of come back from there I'll have me a multimeter this afternoon
