Unfortunately, we had a fire in a big server room. The AC was the culprit. There were like 20 servers in there. The servers didn't actually get burned, but was only affected by the thick black smoke(Soot). Parts of the servers were already starting to rust because of oxidization.
Internal parts are all covered with a black layer of soot.
How would you assess the situation? The servers are no longer usable??
Thick smoke I think will cause a short-circuit, right? If this is the case, then all electronics inside will be just bad. It will be just like dipping the boards in water. right?
What would be the best course of action?
The server room is currently offline(Which is fine because the system they should be running isn't fully deployed yet). We would expect reliable operation from the server room when they start to work, but at the same time we don't to buy replacement servers if the smoke damaged ones can be made to work properly.
I can provide photos if needed once I get them.
Please feel free to ask questions.
Thanks in advance
Thanks in advance
