William At MyBlueRoom
A simple program that lights LED1 Green when an IR signal is detected. Also can be used to test pushbutton #1
; Firefly IR in test and/or button 1 test
; DIP switch dduudd (IR_in on, Tutor on, all others off)
list p=16f88 ; list directive to define processor
include <p16F88.inc> ; processor specific variable definitions
errorlevel -302 ; suppress message 302 from list file
__CONFIG _CONFIG1, _CP_OFF & _CCP1_RB3 & _DEBUG_ON & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_ON & _PWRTE_ON & _WDT_OFF & _INTRC_IO
__CONFIG _CONFIG2, _IESO_OFF & _FCMEN_OFF
; Oscillator select for Firefly 16F88 internal OSC (this also affects USART)
; 0 = 31.25KHz, 1 = 125KHz, 2 = 250KHz, 3 = 500KHz
; 4 = 1MHz, 5 = 2MHz, 6 = 4MHz, 7 = 8MHz
; OSCCON = 0xxx0010 (xxx = speed, bit2 = use internal RC osc)
OSC EQU 7 ;enter desired Oscillator speed
; _let macro similar to BASIC LET X = value
; designed for readability
_let macro register, literal ;_let <register>, <literal>
movlw literal ;W = literal
banksel register ;make sure it's in the right bank
movwf register ;register = W
endm
org 0x000
_let OSCCON, OSC*.16|0x2 ; use OSC value to set internal osc
_let CMCON, 0x07 ; disable comparators
_let ANSEL, 0x00 ; disable A/D inputs
_let OPTION_REG, 0x00 ; weak pullups
_let TRISB, b'11111111' ; all inputs
_let TRISA, b'10111110' ; enable LED 1 (red / green)
banksel 0 ;B0 switch to bank 0
clrf PORTA ;B0 zero port (LEDs off)
IR_test btfss PORTB, 0 ;B0 is RB0 low?
bsf PORTA, 0 ;B0 if yes then LED1 on (Green)
btfsc PORTB, 0 ;B0 is RB0 high?
bcf PORTA, 0 ;B0 if yes then LED1 off
goto IR_test ; loop forver
end
