PIC Timer 1 preload value
augustinetez
Most Helpful Member
Would somebody please check my maths for the preload value of Timer1 on a 16F1827 running at 4MHz.
I'm looking for a delay of 5mS, pretty sure I've screwed this up :oops: because it's taking a lot longer than 5mS on the hardware.
65536-(delay*clock freq)/(prescaler*4) = 65536-((.005*4000000)/(1*4))=60536 (EC78 HEX)
Out of curiosity I converted the above to C, so three lines in asm become 1 in C.
I.E.
      banksel  OSCCON
      movlw    b'01101000'    ;select 4MHz clock = 1MHz instruction cycle
      movwf    OSCCON         ;Set PIC oscillator frequency
becomes
      OSCCON=0b01101000;  //4MHz clock
And the whole thing becomes,
      T1CON=0b00000001;   //Timer 1 on
      CCP1CON=0b00001011; //Special Events Trigger
      CCPR1=5000;         //period = 5000
      while(1){           //loop forever
        while(CCP1IF==0); //wait for CCP1IF to be set
        ;5mS has passed
        CCP1IF=0;         //clear it
      }                   //end of loop forever
Note, CCPR1L/H can be accessed as a 16 bit variable
Trying a version with only spaces,
setup
      banksel  OSCCON
      movwf    OSCCON         ; Set PIC oscillator frequency
      banksel  T1CON
      movlw    b'00000001'    ;timer 1 on
      movwf    T1CON
      banksel  CCP1CON
      movlw    b'00001011'    ;Special Events Trigger
      movwf    CCP1CON
      banksel  CCPR1L         ;set timer 1 to repeat
      movlw    low(5000)      ;every 500 clock cycles
      movwf    CCPR1L         ;equals 5mS
      banksel  CCPR1H
      movlw    high(5000)
      movwf    CCPR1H
loop
      banksel  PIR1
      btfss    PIR1,CCP1IF    ;wait for interrupt flag
      goto     loop           ;to be set
      ;5mS has passed
      bcf       PIR1,CCP1IF   ;clear it
      goto      loop
Edit, appears it's tabs that cause the problem.
I would presume that it's simply that the forum software is expanding the tabs to a different number of spaces than the original editor did?.
