Pete Firth
Hello all, Sorry I'm a bit of a neewb (this is my first post), I have a fair understanding of electronics and circuits but when it comes to resistors capacitors micro controllers etc I'm totally out of my depth!
I'm trying to work out the circuit for what I believe (maybe showing my ignorance!?) should be a fairly straightforward project. and I'm hoping that some of you may be able to help with the circuit design/planning.
The Dream: a simple sequencer that is triggered from an electrical pulse (sent from an existing firing system) triggers a sequencer, i.e. an electric pulse incoming, and on each subsequent input pulse advances to the next output, each output is a pulse of current that goes to an 'electric match' basically a resistor that gets overpowered and burns up igniting a firework fuse or lift charge.
So similar to an led counter circuit where each press of a button lights a different LED, just in this case theres an led and a current sent to the ignitor to fire the firework connected.
The system will be powered by 2 x 9v batteries (18v), there should be a continuity test function with an LED to indicate a complete circuit, and an LED indicator for each output pulse (can use the same LED), the counter should also reset to 0 on power cycle, in theory a simple CD4017 decade counter should do the trick as I only want 6 or 10 queues / channels on this system, the continuity test will need to be at less than 15mA, the ignitors are not sensitive to current direction, and once fired the circuit is broken, however some sort of dead short protection is probably a good idea.
So, its a stand alone system with its own 18v power supply, when switched on it should show/indicate if there is continuity on each of the output circuits, the trigger is a pulse of current from a separate system, each time an input pulse is detected it should send current to an ignitor in sequence [pulse #1 (p1) fires queue 1(q1), p2 fires q2, p3 fires q3 and so on..].
Its worth noting that it should not include any mechanical relays etc, as in a failure this could cause a dangerous occurrence! these sort of systems often employ fets (but I'm not entirely sure I understand what they do..
I hope thats enough information to get started? I think I can get my head around circuitry that would make this work but I'm clueless as to what resistors capacitors etc I would need to protect the circuit and make it function reliably.
Any help would be much appreciated!
Your
maybe transistors are the key to all of this... both my original idea of using a CD4017 to switch to a higher power circuit,
Your 4017 based circuit looks decent in principle, though it needs a high current driver between each output of the IC and the actual output to the load.
Something like this, with appropriate components and values.
The input labelled "Arduino IO" would be from a 4017 output, and "VCC" power would be the 12V or 18V load power supply.
Also don't forget the 4017 will have one output on - it needs a resistor-capacitor-diode "power on reset" circuit to ensure it starts with the same output on to start with, and do not use that output to drive a firing circuit. It could go to a LED & resistor, to show that the sequencer is in the reset state.
The same or similar output power circuits would be needed with a microcontroller based sequencer, as the MCU outputs are only 3.3V or 5V, at low current.
The beauty of using a processor in the solution is :
1) Before firing, using A/D in micro, and a mux, scan the matches for continuity.
2) Safety hold off main match power source until 1) is done, and display a fault
if 1) is found to have issues. Also use A/D and confirm match power is ready.
3) Stop sequence if match fails to fire.
4) Confirm all matches have fired after sequence done.
Safety....may sound wacky I would even consider using a dual processor
solution to confirm main control processor is working properly....this is
done in a lot of medical equipment, space applications.....
Regards, Dana.
