Is is possible to fx FM synthesis sound using PIC micro?
If yes, can anybody give me some hints on how to start it., or some good reference in the web.
Thank you.
What I want to build is an electronics Piano (toy).
It can generate piano sound , with fade out effect,
able to play/mix 2 voice/note simultaneous.
When above is done, I will add recoding & playback function.
Currently, what I have is using PIC micro to generate the music note.
But it is square wave only, how I do "fade out" and mix atleast 2 notes?
So I am thinking of FM synthesis technique, because it can generate a close to piano sound effect.
I have try PWM & wave table method, but look like my 20Mhz PIC don't have enough house power to do the job, the sound is horrible...may be problem due to my un-optimize C code.
Another idea is interface to a simple analog circuit that can generate
require tone/wave with fade out.
How is actually the electronic piano(toy) generate sound?
Any suggestion?
Thank you very much.
Check out Don Lancaster's magic sinewaves. It is a way to make low distortion PWM sinewaves. 20 mHz should be adequate. https://www.tinaja.com/magsn01.asp
maybe you should just buy a synthesizer. they arent that expensive and can do alot more than what you are trying to do, so it should keep you entertained for a longer period of time.
