Is there a simple but yet powerful FM transmitter that I can build? I'd like it to have a 2-4 mile range and to allow me to change the frequency from 88-108mhz. Thanks for any help.
I can't help you with the 88 - 108Mhz frequency range.
But if you would like to go to a much higher frequency 5.8 - 5.9GHz, you could get a much further transmittal distance as well, have a look at.
ADF7025 - Analog Devices
ADF7012 - Analog Devices
ADF4016 - Analog Devices
All used in conjunction with each other. you can transfer baisically any type of data or voice.
You could also have a look at
TRF6900 - Texas Instruments.
still not within the frequency range but worth a look.
you might want to include an FM modulator with the TI chip to lower to those required frequencies.
But i can assure you it will be near impossible to get a 2 - 4 mile range in that frequency range. you would need at least a 50W transmitter, depending on your area as well, there are many factors contributing to the power required.
50W infact would not be required to transmitt that distance.
If you used the Analog devices IC's in conjuction, 1Watt of transmittal power would get you about 10-15kms (6-9miles). the analog devices IC's provide that amount of power. if you wanted to amplify if further you also could if you like.
Maybe I exagerated in the range, I'd like a 1-2mile range, 2-4 was a little off. Therefore, can anyone give me a schematic of a transmitter that I could build, I'd like to use it as a neighborhood radio station. Thanks! :lol:
