MeAndYou
Hello,
I’m trying to interface a “Speed Sensor” of a bike with a boost controller and I’m not too sure what I should use for my problem. What I need is a frequency divider. The frequency at the input trigger is continuously changing, since the pulses are in relation with the speed of the bike. I receive 687 pulses (as per the manual) at 60 KM/h (36 miles). I’m expecting that the relation between the pulses and the speed is linear. Did not have the chance to put the signal on a scope meter. The signal from the speed sensor is a square wave (High=5Vdc and Low=0Vdc). The speed of the bike is (0-320Km/h, 0-192 Mph). On the pin of the boost controller I have 5Vdc and I need to short that pin to the ground for that device to see a change.
The boost controller has a few ratios that can be chosen, but none of them give me an acceptable reading. So, I need a circuit that would tweak the ratio before it goes to the controller. I’ve looked at a LM555 and even if it says in the datasheet that it can be used as a frequency divider, I don’t see how it can work if the input signal is continuously changing. In a monostable configuration, the Output will stay high until the “temporization” is completed even if the input signal is retriggered many times during the temporization. It would work if the frequency of the input signal always stays the same, right?
Ok, what I’m looking for is a “Frequency Follower” circuit. This circuit would give me the possibility to adjust the ratio from 7 to 12 (potentiometer) with a transistor (NPN) that would act as a switch between the circuit and the boost controller to short the 5Vdc to the ground when the output goes High. I understand that there will be a delay in the response, but it is acceptable. Any ideas or ???? Thanks!!!
![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
