Fuel sender 0-5v help
What I posted is a schematic. You are asking for a pictorial diagram which shows physical parts. I dont have time for that.
You can do it. Start by printing out the data sheet for a LM358 op amp. It will show you pin numbers, etc. Get a piece of perf. board. Make a xerox of the bare board. Start placing components such as to minimize wire lengths.....
I plan on building pretty much the same thing. My fuel level sending unit outputs the same range of resistance. I have one question... will any op amp work? I found a NTE975SM at radio shack...
Unfortunately no. The specified LM358 will pull its output pin close to ground (required); the NTE unit will not.
Do you have the required 5V reference voltage you can tap?
The ecu has a regulated 5v output. There is a Adc circuit on the ecu that accepts 0 - 5v. However i dont need to have it exactly from 0 to 5... i can have it from say... 1.5 to 4 volts and just scale the gauge in the software to match. whats important is that its linear.
The circuit will more linear than the damn sender.;)
To make the system ratiometric, it is important that the sender be fed from the regulated voltage...
