Full bridge PWM converter
Archit
Hello people,
I want to generate 350V from 40V using phase shift full bridge topology. Can anyone tell me where I am going wrong? How to choose magnetizing inductance? I have attached my model. Frequency of operation is 100KHz.Thanking in anticipation.Please Help
  • trying pwm phase shift.asc
350V & 25 ohms = 4900 watts. Is that right?
40V & 120A = 4900 watts. You are using 800 V MOSFETs and you should be using 60V and much lower Rdson parts.
Also changed the diodes from 0.2A to 5A. Should be 10A but no problem in SPICE.
  • trying pwm phase shift-ron.asc
Changed the switch but still not working.
You need to revisit the gate drive arrangements. At the moment you're getting a nett 12A or so standing current through the primary winding.
Then try the file I posted. I removed one inductor because you can not ramp 30uH from 100A to -100A in a very short time.
but I need that leakage inductance for Zero voltage switching of my mosfet. Also, I have one more confusion, that transformer practically implementable?
OK, You need some. But you can not force +/-100A through a 30uH inductor with only 40 volts. Add back the inductance and make it small like 30nH. (I don't know but you need to move from -120A to +120A in 5% to 10% of your switching time, with 40V across the inductance.)
10%=1uS, 5%=500nS 2.5%=250nS
delta current 240A
Voltage =40V
This is hard. You need to start another thread. Read a book.
delta current 240A
Voltage =40V
Thankyou. I have one more doubt.Does magnetizing inductance be 30uH or 30uH+(3/n^2)mH. Will the secondary side also reflected in magnetizing inductance?
