throbscottle
I've been trying to get the output half of this to work: http://www.kerrywong.com/2013/06/05/vfd-filament-driver-using-555/comment-page-1/ I particularly want to use a transformer so I can connect the centre tap to -24v or so (+ offset).
I have a green ferrite toroid 14 or 15mm diameter, originally had about 8 turns bifilar on it, came out of some sort of PSU. I tried some smaller ones first but didn't get enough output with them.
I wound it as per the web-site, 30T secondary CT, and 40T primary. Drove it using my pulse generator set to square wave, started with 100KHz but tried tuning up and down from there.
Output looked good open-circuit, dropped very low when connected to VFD filament. Tried more turns, voltage went down. Tried less turns, voltage went up. OK so impedance matching going on there. Tweaked to find best number of turns.
Fiddled with the primary next. Tried reducing the turns, but the secondary voltage went down! Ahhhhh, what's going on????
Ended up changing turns so much I lost count, but I think I've ended up putting an extra 20 turns on, so primary is now about 60T and secondary about 26T, and yet I have 5v going in and 2.2v coming out with the VFD filament connected. I can't get the voltage to go up any more except by increasing the supply voltage. Get a bit more output at higher frequency (about 142KHz), I'm guessing due to resonance, and a lesser increase at a lower frequency, somewhere in the mid 80's KHz. Also improved by changing transistor (don't have a BD131 like he uses, ended up with TIP31 I think)
I also experimented with the catch-diode. Tried putting it directly across the primary but the output drops completely, back in it's proper position for some reason it now makes no difference although it did before I fiddled with it![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I think the VFD filament needs about 3v (don't have actual data for the display, it's a Samsung INRC09SS49T in case anyone is familiar with it.
So can anyone help me get more output from this circuit without having to so finely tweak the transformer (in fact, get it to behave more like a power transformer) and without resorting to a significantly higher supply voltage (increasing the supply voltage from 5V to 12V resulted in only 0.8V increase in transformer output). I don't mind making the circuit a little bit more complicated but not forgetting it's only to drive a filament so there's a whole bunch of stuff it doesn't need...
