GBPT used in charging
KevinW
Anyone happen to know what a GBPT in charging a lithium battery is?
Marked u1 and u2 on the board.
The charging portion is separate on this flashlight.
I couldn't find anything on these GBPT components.
The flashlight has a red and green indicator for the battery and it's been in the red when charging but when I just looked at it, it was still red and then switched to green when I started running my hand over the components looking for a heated defect.
I must have touched something that caused the indicator light to switch from red to green.
I believe you are right RJ, I have 4 volts going into it and nothing coming out, probably because the batteries are charged and the ground is where it should be so thanks for all the information you posted.
