GE 15089 digital switch
KevinW
I have a light timer/switch that doesn't switch a light on or off unless I control it manually.
Could a defective 32.768 crystal oscillator be suspect?
The clock/time settings seem to work properly.
I have found that the NiMh cell is a common fault on these plug in time switches. Sometimes they do not hold a charge and somtimes they seem to go open circuit so that when they are plugged in the charging current raises the voltage abobe the normal battery voltage and this causes allthe segments of the display to be dark. Does the time display increment normally ? If it does then the crystal is OK.
The actual timer part is under a black blob of resin on the board with the display. The board in your picture is just the relay driver and charging circuit.
Les.
Hi Les.
The display is normal.
I looked for a timer but couldn't find one.
After reading
I found it under the display as you mentioned, thank you.
Hi Les.
After reading
As Les said, check the battery - although I'm not familiar with your exact device those batteries are extremely prone to failure, and often cause strange faults.
I have it working again.
Very fine minuscule white deposit across a trace.
Cleaned with isopropyl and all is good again.
Thanks for your input.
