Cantafford
Hello,
I have made a project in which I control the speed and direction of a small DC motor using a PIC18f2550 microcontroller and an integrated L293D half bridge. I have simulated it in Proteus and it works fine.
The L293D truth table is this:
This is my schematic:
As I'm sure it's obvious the project is supposed to work this way:
-I press one of the buttons to select direction: CW or CW(RB0 or RB1).
-then I select a speed from Rb2-Rb5 in ratios of 1/4(25%, 50%, 75%, 100%). The CCP1 of the PIC is connected to the enable pin of the L293D to send the PWM signal.
The program is supposed to let me select a direction then the speed in four ratios. It works fine in Proteus.
However I implemented it in hardware and I have one problem: When I select the speed to be 75%(press the RB5 button) the speed goes briefly to 100%(full pwm signal) then the motor stops and no further commands can be given(I have to reconnect the power supply to make it work again). Again this is not happening in simulation only in hardware.
Now this pin is the PGM pin. I have googled and I found out that you need to turn off LVP(low voltage programming) in order to use that as a GPIO pin. If I try to set LVP to 0 the program that not work at all(at least in hardware have not tried that in proteus).
I have made two videos to make it clearer what my problem is:
1. Proteus simulation:
2. Hardware implementation:
I'm guessing it's a software issue but it seems strange to me that it works in proteus.
![33ubqx4.jpg](https://i66.tinypic.com/33ubqx4.jpg)
![29axxn9.png](https://i66.tinypic.com/29axxn9.png)
