I have an old house circa '65 in Winnipeg when my 14yr old nephew moved in with his Swiss toothbrush charger, I made him by instructions, knockout a hole and install a GFCI in the bathroom.
One wierd thing I did was I opened up a 30 A outlet at work, pulled out the wires and connected it to a HUGE 200
A MIG/TIG welder. It didn;t look so hot, but only a 1/4" SS line had to be welded. "Temporary Power".
Then I needed a way to activate some solenoid valves on a vacuum chamber (hi vac (Cryopumped), rough, vent) until I could repair the valve controller. I stuck the wires into the outlets of a switched outlet strip. It worked for the few hours I needed and it kept the machine operational. I know I did it twice for two different systems. It could have been a diffusion pumped system.
I remember the hair standing up on my arms and head with a tickle when I powered a 50MVA transformer with 100kVdc on top to test the insulation and walking outside the safety fence created this whereas 100kV ac does not as the DC charge leakage currents are higher with DC modulated by 120Hz rectifier. which created the tingle sensation on my scalp..
Even more interesting was the bugzap sound on the wall every second 100 ft away due the same E field. tick tick.... until I ground some floating rails mounted on the wall with a tiny wire to earth ground. It was annoying sound for some. Meanwhile we were 10 ft away outside the fence.
At no time was I nor anyone else helping me with my experiment at risk.
For a while I felt what Benjamin Franklin must have felt.
lucky.
even tho the fence was grounded , you could still get a zap from touching the epoxy paint.
Similiar to touching an old TV tube made from leaded glass for both Xray and ESD reasons.
lucky.
apparently, still alive i joined local ''club of ee hobbyists'' so far, pretty interesting place, good thing my buddy invited me! fee is only 10€/month, and that includes pretty much all.
Nothing interesting found for tearing apart, except cash tester, which had bunch of IR-stuff and so on. (i do have pictures of it, just need to make article of it).
Oh, and one bigger project is almost done: 8-freguency-band light organ, made completely without microcontroller, all by discrete components. Just need to buy case & solder MANY components....
