carbongixxer
Smanches, so do you think I should just go ahead and replace that 16v 470uf capacitor with 2 25v 1000uf capacitors?
With this chip the only external parts you need are the two filter caps and an inductor. It's about the most simple SMPS you can build. If you were to build it from discrete components, there would be much more to do.
Most likely, the chip is not behaving exactly as expected and has more voltage ripple than the video system can tolerate. Adding a newer larger cap, or an additional cap (on the output) could help a lot.
Hayato: I know it's there. I'm not sure what you were pointing out? I was talking generically about the chip itself, not the specific charger.
It has always had the lines when I connect the charger. Its connected to a always on cigarette lighter.
The 2 1000uf caps should be wired in parallel, correct?
