i am building a switch box, so that i can run multiple digital audio cables into the box, and have a single output, that is switchable.
my question is:
can i just run a single wire through all of the incoming ground contacts, and have that same wire go to the ground on the output?
i know this is a little hard to understand, without knowing exactly what i am doing. just try to imagine a panel with a bunch of rca jack on it (8 to be exact), and i am using 7 of them as inputs, and one as an output. can i just connect all the grounding points as one connection, and not even bother with running ground lines through the switch?
my question is:
