Guitar electronics project
GuitarMan
This is a request for ideas in design and components to build an electronic circuit to control the pickups in an electric guitar. It goes beyond the usual modifications published in the music community, and requires some familiarity with standard electric guitar circuitry, understanding of how more sophisticated controls than RC circuits work, and will likely involve custom fabrication, although I'm hoping to avoid that.
The project:
I have spent many years playing guitar. I own what is not a huge collection, but certainly what is decently representative of the various categories and varieties of that instrument. I own acoustics and electrics, solid bodies and hollow bodies, 6 and 12 strings, classical and jazz.
Most of them are well-known makes and models, even if vintage, but then again, so am I.
With the acquisition of a 3 pickup Les Paul SG Custom, I discovered that the stock configuration gave me very limited choices where pickup selection, volume and tone were concerned. I began to consider how I might improve the situation, and that is where the idea for this project was born.
This particular guitar has what are called "tarback" humbucking pickups[1]; they have wound bobbins immersed in a hardened black epoxy resin. There is no way to modify them; any attempts at that will likely destroy them, and considering their particular "vintage" sound, that would be a loss.
Many, if not all, pickups today come with at least 4 lead wires, providing the ability to split or tap the coils in order to provide a wider variety of sounds available from them.
That won't be a part of this project, because as I said, the extra wires are not available on the pickups in question here.
How to control those sounds is an entirely different, and complex, matter. The classic layout for a two humbucker guitar is a pickup selector toggle switch offering three positions (one pickup, the other or both), and a set of four potentiometers controlling the volume and tone of each pickup. The sum output is made available at a jack into which a cable is plugged.
Add a third pickup into the mix, and things become significantly more complicated.
The two largest capacity manufacturers at one point were Fender and Gibson, although I'm not sure if that remains the case, particularly with so many foreign manufacturers, Oriental in particular, now in the game[2].
Their best known and most sold models are, respectively, the Fender Stratocaster and the Gibson Les Paul. Those instruments have undergone a myriad of transformations in configuration, but in the end, each one remains essentially what it was; the Stratocaster a three-single coil pickup guitar, and the Les Paul a two-humbucker pickup guitar.
The Fender Stratocaster has a standard configuration of a 5 position (originally 3, but players achieved the other two by carefully balancing the switch between positions) knife selector switch, a volume and two tone controls.
At one point, it was decided to release a three-pickup version of the Les Paul, widely prized for that additional hardware, and at least the perception of a wider range of available sounds[3]. The same was done with the Gibson SG, of which mine is one.
The 3-pickup Les Paul has a standard configuration providing a choice of the neck pickup (the one farthest from the bridge), the bridge pickup (self-explanatory), or the middle and bridge pickups combined. The four potentiometers provide volume and tone control of the neck and bridge pickups, respectively.
The 3 position pickup selector toggle switch is implemented as a set of leaf springs, where contacts are opened and closed mechanically as the toggle is moved.
That has distinct limitations and issues. One of them is that sooner or later the leaf springs will tire, requiring the switch to be replaced. Another is that adding more selection options would require progressively large numbers of leaves crowded into what is already a restricted space, and with finer distance tolerances, which equates to a problem waiting to happen.
Clearly, that is not a reasonable approach.
Another concern is that as more positions are added to the switch, a larger number of lead wires need to be attached and snaked through to where the pickups are situated (sometimes in a different cavity).
Adding more wires is also highly undesirable, as much for their impact on the circuits as for the real estate they consume.
At best, the market offers a six-position toggle switch. This was a feature of the "Jimmy Page" version of the Les Paul. I don't know the manufacturing source of that part, but apparently it is no longer available. There is a company named StewMac (with whom I also have no affiliation) which markets a "Free-Way" toggle switch that implements the same concept.
The problem is that even that switch doesn't begin to address the possible combinations of a 3-pickup configuration.
It is possible to wire pickups in series or parallel. It is possible to wire them in-or-out of phase with each other. It is possible to wire them in series with one and parallel with another.
Personal taste being what it is, and the history of guitar modifications being as prolific an industry as is that of manufacturing the original instruments, a musician constrained to a handful of options which they had little, if any, say in the matter of choosing, will be left, at best, unsatisfied.
This project is an attempt to address that crying need.
If it is successful, there will be many guitarists crying tears of joy; if not, well, let's say a disgruntled musician is a poor choice of companion.
As for myself, hope springs (at least until the springs tire) eternal.
To begin:
Goal:
The goal is to provide the maximum number of possible combinations of pickup sounds as possible, given the following considerations:
-We don't want to go drilling holes in the instrument if at all avoidable; many people who will find this device attractive own vintage instruments they do not wish to abuse or destroy. Optimally, there will be no apparent change in the appearance of the guitar, in spite of the substantially greater flexibility it gains.
-We don't want to increase the physical count of controls; that would violate the above consideration, and impact another matter which is very significant to a player, especially one who is working professionally. One of the advantages of the limited configurations is that it doesn't require an extended thought process to choose a given configuration and go about their business, namely actually playing music. These are, after all, people who are being paid to entertain an audience, not experiment in a lab. One can hardly stop in the middle of a piece, beg the audience's forbearance while settling on a group of settings, and then proceeding[4].
The typical components which make up the control devices on a Les Paul style guitar are a 3 position toggle switch and four continuous revolution potentiometers, which is to say that they do not have detents with fixed amount of resistance, but rather that the wiper runs along a track applying progressively greater amounts of resistance to electric flow.
The potentiometers themselves, by the way, are also available in a variety of values; typically 250/500k, and with linear or audio taper. We are not going to explore those options in this project, but they are certainly worthy of consideration for a subsequent iteration.
Another feature of the potentiometers we mean to use is that they are available in concentric versions, which is to say that each one is able to contain two independent controls. This will be highly valuable in the sense that we can add controls without drilling, as per consideration #1.
Yet another option is for the potentiometer to have a switch at the end of its revolution, which typically disengages the control from the circuit, but is not really limited to any particular function; it is as useful in the same degree as our imagination is wild.
Still another feature is that of a mechanical "push-pull", where the consequence of having the control "in" or "out" results in changes to the circuit; again, this has no real limitation in terms of how it can be used.
There is a control which has been in sufficient use by significant players to make it worthy of mention, which is the mini toggle switch. Sometimes you have to look closely in order to realize that it is even there. A brief discussion of the uses it has been put to is in note 5 below. I don't want to include it at this time, since it violates both considerations of complexity and cosmetics.
Cosmetically, there are always options such as lighted switches, particularly those which change color depending on their state, which would be a page taken from the world of keyboard technology. In a dark room, it would be a profound boon to the player's clarity on where things are. That is not insignificant, as I mentioned above; the fewer controls a guitarist has to monkey with (no disrespect intended to monkeys), the better off they are.
There are long and bitter debates in the guitar world on the place where all of these options intersect; is it better to have independent controls for volume and tone on each pickup, or is that a complete waste of copper ? Should there be a way to independently control that squirrely third pickup using a potentiometer (raising or lowering the volume in order to include or exclude it in the mix), or should that be handled in the already burdened pickup selector ? What kind of impact does each modification of the stock circuit have on the tone (after all, good tone options is our objective here) ?
I am not going to wade into that quicksand; rather, I am going to impose my view that pickup selection is best done all in one place, and volume and timbre controlled elsewhere. If I have to fiddle with multiple controls in order to accomplish the single goal of choosing my pickup set and configuration, I am in trouble, because a bunch of bars will have gone by before I get all of that done (way too many "b"s there) and am ready to play the next one.
Accordingly, my specific goal is to make the pickup selector offer up as many permutations as I can squeeze out of it.
That will not happen with a 3 position toggle.
Here is what I came up with, after sufficient chemical reinforcement:
A mechanical toggle switch physically makes and breaks the contacts which define the circuit through which signal travels. Getting beyond that count of 3 is not easy; 6 is as far as the manufacturing/engineering community is willing to push it (no pun intended). Mechanical is too limited for our purpose.
This is where I include another feature ordinarily part of a different control, the push-pull action. If I can do that, I double the number of options to 18. That may still not be enough, but it is certainly a vast improvement over 3, or even 6.
Now we come to how the physical implementation of such a device might look.
Well, almost. Before we do that, I want to introduce what I think is critical to the successful implementation of this concept.
This next paragraph is certain to stir up the hornet's nest, so let's all take a deep breath and put on our bee bonnets.
Mechanical controls are prone to failure. My prized Gibson L6-S, which is, as I understand, something of a rarity in terms of how well it has stood up to years of use, has finally come to the state where its potentiometers have become so worn down that setting them produces, at best, inconsistent results.
Electronic (there, I used the word) components are much less so.
At this very moment, hordes of purists are weaving a rope and debating which tree they are going to hang me from, but if I will be allowed a few moments before the chair is kicked out from under me, there is a consideration I want to present.
It is well-known that the farther a signal must travel in a wire, the more prone it is to issues; accordingly, as best exemplified in the microprocessor industry, the less distance that signal needs to travel, the better.
While all sorts of debates rage on about quality of sound as signal progresses through circuits, this is certain: selection of components, such as pickups, for inclusion in a circuit is a discrete and digital act. A pickup is either in or out, in phase or out of phase, series or parallel. There is no known instrument out there (with the possible exception of something Frank Zappa built) where a pickup is engaged in a quasi mode.
That binary state is absolutely best suited to a digital transmission.
So what if I translated the pickup selector state into a digital value transmitted economically through a small set of wires (or even better, optically) to a circuit at the pickup end of the system, where the physical engagement of pickups is accomplished by a set of (relays ?) ?
Now I have eliminated the complexity of the leaf spring device and its mechanical challenges, and efficiently transmitted the neccessary information to the place where it is needed, at the same time dramatically reducing the actual signal path length.
For those of you who insist that having that signal path and mechanical switch lie at the heart of what makes those guitars sound as they do, I have no answer. I'm sure, however, that someone is prepared to make the measurements required in order to feed a pickup modeler circuit (I can feel that next multi-million dollar project coming on) in order to restore whatever magic was lost.
So now we need a 9 position joystick control, with the 9th position being centered, and we need it to have a push-pull action. Then we need a way to detect and encode the state of that switch in order to transmit that information to a receiving circuit at the other end.
The receiving circuit will need to have access to all of the leads on each pickup, which in this case is 6 (2 per pickup), and the ability to route the signal to and through them based on the transmitted state of the toggle.
That is one part of the project.
The second part is the disposition of the 4 potentiometer controls, and the level of complexity I want to impose on them, with specific objectives.
Here we plunge into yet another topic fraught with controversy; which controls to use for what, and how many of them should there be.
The answers to those questions have substantial bearings on the level of complexity where the signal routing circuit is concerned. Not only do I need to apply the player's choice of pickup configuration to the signal path, I also need to get said signal through the series of volume and tone controls which shape the output before it exits the guitar.
As I said above, there are concentric and push-pull options, as well as switch options. I have never seen a concentric push-pull control, let alone one with a switch, but this much is certain: each element adds to the length dimension in a place where there is precious little real estate to be had, so miniaturization is our friend here.
The best possible configuration here would be an open-ended programmable one, where the complete mesh of options could be accomodated. That would require no physical routing, particularly if access to the routing module were made wireless (I shudder at the thought of a USB port gaping from the side edge of a beautifully crafted instrument; that would be absolutely sacreligious).
It would also lead to a dramatically greater level of complexity in the implementation.
At the same time, it would yield a highly personalized configuration, in exactly the way a keyboard player has the benefit of. Even keyboardists who own the same make and model of instrument hesitate to use each others' gear, because the customizations are so involved that the same physical keyboards can sound like two entirely different devices.
In a way, that is part of the goal here; to provide the guitarist with the ability to construct his unique voice.
There is no substitute for practice and technique. All of the dials and buttons in the world cannot produce a superlative musical experience. That requires a human touch.
But there are few things as inspiring as the 64 crayon box (which my sister got, but I never did) on which to build.
In the end, that is what this about; crayon envy.
When I bought that Gibson L6-S, my first electric guitar, it was featured in an ad graced by Carlos Santana, who called it his rainbow. I found that a powerful motivator in choosing a first instrument, and I was not disappointed. In that case, however, I am loath to monkey with it, both as a consequence of it having so many options as it is (6 position "chicken head" pickup selector, and both tone and midrange controls), and because it is pretty much perfect as it is.
The Gibson Les Paul SG ? Not so much.
If I don't return to continue this project, you'll know that the purists got me.
Notes:
[1] A humbucking pickup is a device which contains a pair of wound bobbins wired so as to cancel frequencies which are considered sonically undersirable. That, of course, is entirely subjective, but given that a huge portion of the market belongs to that type of pickup, apparently it has gained acceptance.
[2] It must be said that although there are indeed companies whose product is substantially inferior, there are many with output which is absolutely superior in every way. I myself am a big fan of Yamaha steel string acoustics (I don't own stock in that company, nor do I have any affiliation with them or get paid anything for saying this). I don't think you can find an instrument of better quality and sound at that price point.
[3] Thankfully, Fender did not respond with a four-pickup version of the Strat.
[4] Interestingly, keyboard players typically deal with vastly more complex interfaces consisting of many dials, buttons and sliders, with a video display and a slew of multi-colored lights blinking at them, and yet they are expected to make all of their selections "on-the-fly" and seamlessly proceed from one section of a piece to another. The response of a guitarist to such a daunting ? would likely be something akin to a deer in the headlights. It may be true that it has become fashionable to have a "pedal board" filled with a dozen or more effect devices, but there have also been many product offerings intended to clean up that situation and fold many effects into a single box. Even so, the keyboard players are clearly at an advantage, given that they deal with anything from 62 to 88 keys, whereas guitarists struggle with six strings. It may explain why guitarists have a bad reputation for smashing their instruments, which is a very rare event among keyboard players, indeed.
[5] Mini switches as used on guitars are always toggles, usually with two positions. They have been used to include or exclude individual pickups from the signal path, splitting the pair of coils in the pair within a humbucker pickup, and controlling other options. The issue is that by the time you have added enough of these to manage all of the options, that surface resembles a pincushion more than a guitar top, and may result in injury to the instrument, the player or both.
You have four pot positions, each of which could be swapped to a push-pull.
The pickup selector could be swapped to a rotary switch rather than a toggle? eg. as an example of a readily available style:
The four pole, six position one is only about an inch deep. A three wafer one is still only 1.2" or so, which I think should still fit easily?
That allows for multiple positions with no irreversible mods.
Four push-pull x 6 position rotary = 96 combinations??
(I've got a Les Paul and an SG as well as a few others, but I've never worked on a three pickup Gibson so no idea on the body routing & cavities).
Electronic / relay selection is possible, though it would take a lot! more space than just switches.
The wire length in the guitar is irrelevant as long as the cavities are screened.
Digital / microprocessor connection lengths are limited due to signal frequencies, speed-of-light delays and impedance matching - totally irrelevant for general audio or within a guitar.
TL,DR
lightium:
The backstory is there in order to clarify what I am trying to accomplish and why. I understand that I am presenting a complicated project, so if the post is too long, I understand.
rjenkinsgb:
Congratulations ! You are the first response to my posting. That wins you a free beer. It's in my fridge. Come by for it any time.
Firstly, seriously, thank you for the reply.
in order of your responses:
True, there are four pots, and not only can they be push/pull, but concentric as well. However, as I mentioned, I want to avoid splitting the pickup selection function between multiple controls, as in pickup selector toggle and pots. Way too much work and not enough time in which to get that done before I need to go back to playing. Some players only adjust that selection between verse and chorus, or rhythm and lead, but that isn't true here. Think Jeff Beck.
Rotary switch = evil, well, not quite that bad, but far too slow to get the job done, not to mention strain on the wrist when you need the positions at the extreme ends of the rotation. I have experience of this with my L6-S, which as I mentioned I am deeply attached to, but that chicken head is one thing I would gladly change.
The cavity in the SG is only about 1.25" (although I haven't measured mine), so that is a significant constraint. The Les Paul is deeper, which corresponds to the depth of its body compared to the fairly thin SG.
When you do the permutation math, you forget to consider that nothing is left to control volume and tone for each/any pickup. That's a non-starter. As I said, one of the design considerations is to avoid splitting the pickup selection function between multiple controls.
The difference between a Les Paul and an SG in terms of cavity and routing is this: the Les Paul selector is located in the top upper bout (area closer to the neck and to your eyes), while the pickup cavity is located amidship, with a wire routing tunnel between them.
Electronic/relay selection (or some non-relay method) is exactly what I am after. I am hoping that a) miniaturization is my friend, and b) transmitting information like selector toggle position digitally would be easier and less complicated than a leaf spring mechanism.
Wire length is very much a consideration, and although for some digital applications that metric won't be significant, it will be distinctly audible. The multiple signals traveling through the circuits (pickups generate signal even when not selected) have an impact, as does the metal used (silver vs copper), the diameter of the wire and the pots themselves all affect the sound. Even though the cavities are foil-lined, individual wires from the pickups are still covered in braided shield, which wouldn't be required if there was no issue. Wire length changes the resistance. The measured quantities of these differences might be very small, but the end result is meaningful.
I will grant you that speed-of-light is not significant here, although I am very much interested in an optical connection between the selector switch and the circuit which actually makes and breaks connections, but impedance, being that it is a distinct measure which applies specifically to pickups, being wound coils and rated in terms of Henries, is absolutely relevant.
Everyone is welcome to join this discussion, so don't hesitate to jump right in.
I should also say that I don't consider my statements to be absolutely authoritative, so don't hesitate to call me out on them. I am here to learn.
So what would you accept as the selector, given that the number of connection permutations to both ends of at least three pickups for series/parallel/phase combination selection is probably greater than 20 (I haven't done the maths) ?
Thank you for the reply.
I think that at the heart of this project lies a piece of hardware that may not yet exist.
There are plenty of joysticks to be had.
I haven't tracked one down yet, but I know that an 8 position joystick ( as opposed to an infinitely variable one) does exist.
What I need to make happen is an 8 position joystick with push-pull functionality, where the position of the switch is interpreted based on which position the push-pull is in.
Maybe this part of the project requires an engineer with both electronic and mechanical expertise. On the electronic side, there needs to be a circuit which translates the physical positions of the switch and push-pull into a number, and then transmits it to a circuit which translates that number to a selected group of connections resulting in the desired pickup configuration.
I suspect that I am more likely to find the translation of switch position to a number, transmission to a selector circuit, and most complicated, the circuit that makes connections of pickups based on that number.
The outcome of developing the configuration I am describing is 9 positions (with the 9th centered) and two levels of push pull for a total of 18. That may not reach the full number of possible combinations, but it will be close.
I think a 5 x 5 switch array, e.g. as used on a pocket calculator, might be more practical than a joystick; but I'm no guitarist.
The pots are still pots.
The push/pull function does not affect that. The common Jimmy Paige mods for the Les Paul use push-pull pots to give 20+ pickup permutations; the volume and tone pots still work exactly the same - I've done that on one of mine.
However, I'm now totally lost on what you actually want to use as physical controls to change selections???
Being able to do the switching electronically is one thing, but it needs physical controls somewhere!
ps. With good quality low capacitance screened cable, the length of the wiring within the guitar is not relevant.
The actual loading effect would be capacitive, but again irrelevant - exactly the same as using a slightly longer lead from the guitar to amp.
(Cable resistance is milliohms, vs. several K Ohm for the pickup).
You could do a 32 button keyboard using wifi connected to a small ESP32 WiFi board in your guitar? The switch request could be transferred on a closed network within 1/10th second (usually less). The WiFi board in your guitar could be set to which when amplitude is low or on (near) a zero-cross to avoid pops.
The same could be done with Bluetooth LE if you need a longer battery life. Instead of a 32 button board, it could also be an app on your phone.
Let us know what you need.
I think that I have made this thread unreasonable in the sense that there are far too many moving parts which I threw on the table all at once.
Let me cut this into smaller pieces, and hopefully get the project assembled from a few parts.
I am fabricating a toggle switch that has 9 positions, 8 around the edge and one in center.
The body of the toggle moves up and down with stops at three levels. Visualize a cylinder riding inside a body with a round hole.
The first function requires that a sensor reads the stop position of the switch body. I am thinking a proximity sensor underneath the switch. It would need to be very thin. I am thinking that there needs to be some kind of thin metal tab underneath the moving cylinder to make the cylinder depth easy to read.
The second function requires 8 sensors placed around the outer cylinder at each of the 8 toggle switch positions. Distance between the toggle shaft and the sensor is going to be very small, so the sensor needs to be very sensitive.
The result of this arrangement gives me indication of 9 toggle positions (no output from any of the sensors meaning toggle at center), and indication of depth level. I need to translate that sensor data into selecting the permutation of guitar pickups in the following way:
Some kind of silicon needs to receive the sensor output and translate that into a set of output signals. A set of gates in the pickup wiring will control the signal path, to give me the combination of pickups indicated by the sensor data. There will be something in the range of 20 gates.
I am hoping to make this happen with logic, and to avoid a full blown processor. There is not a whole lot of space for an Arduino board.
The gates need to be controlled by those signals, and pass or block audio signal accordingly, so control would be a digital signal, but the gated signal needs to be analog.
Given a physical switch body that carries all of the parts, what I am hoping to get here are the parts that provide the function I want.
Processor or logic, you need analog switching devices that can handle the peak signal levels without distortion - and something to power them!
That means a lot of space to fit everything. Where is it going to go? I don't think there is enough space in an SG body, without routing so much away it's unusable.
You need a battery compartment.
(I don't see the point of using an MCU anyway - the switches are critical part, however they work).
If you are using logic signals, the switch does not need 24 individual outputs. It could be an 8 way with the whole body moving between three positions using detents, plus three sensors to detect which detent it is in.
Using a commercial 24 position rotary switch wafer edge-on over 1/3 rotation could give the 8 positions without sensors, just needing the detent mechanist adding and the sensors (or microswitches) for the three stages.
You could use subminiature microswitches for positions around a fabricated switch, eg:
ps. You can buy guitar pickup switches up to 10 way, off the shelf:
Can you come up with a list of all the actual pickup permutations you wish to be able to select?
I can think of these:
Eight [seven] three-pickup combinations;
Twelve [eight] two-pickup combinations;
Six [three] single-pickup combinations.
However, seven of those [in brackets] are redundant, as set each include reversed phase on all selected pickups, which is no different to all normal.
That leaves 20 possible, functional, combinations.
And, of the non-redundant combinations, how many can a listener differentiate?
The Freeway switch seems to optimize selection and simplicity.
I recall fixing an electronic synth pedal box for a bass guitarist. It was circa '77 from Silicon Valley and he played with my buddy www.PeterAllenAssociates.com. It had a couple dozen discrete CMOS logic ICs and analog switches with the part numbers sanded off. It produced dozens of effects including flanger, wah-wah, reverb, echo and jazz upright bass plunk sound. It was easy to fix and was a design error with CMOS threshold tolerances shifting levels from polar to bipolar.
All the effects were preset with a rotary numbered switch. I should find out what happened to it.
Indeed.
In fact thinking about the permutations again during the day, about half are just inversions of others, so less again in total. (eg. with three pickups in circuit, having #2 out of phase is the same as #1 and #3 out of phase - same end result. Likewise for any two pickups - it makes no difference which of the two is inverted).
Three pickups: Four total permutations.
Two pickups: Six total permutations;
One pickup: Three permutations.
