Yes, the bottom clamp diodes are backwards.
neither have I some learn by releasing the magic smoke for themselves i guess...
I've never seen an h-bridge with the diodes forward biased in the bottom quadrants. Is that by design ronv? Looks to me like they would short out.
Oopps! Yes the bottom ones are backwards.![]()
Flavin, There is one other thing we should address. This driver requires that the duty cycle not be held at 100% because the boost cap needs to be recharged. So you need to limit the duty cycle in your micro to like 99%. Don't know if that causes a problem or not.
Are you going to run it from a battery or a power supply in the final version? The reason I ask is that if you run from a power supply you need to be careful that the motor is stopped before you reverse direction or it will "pump up" the supply and may cause problems.
You should be ok with the limit switches.
You should be able to disconnect the power supply and measure from the top of the bridge to ground with the ohm meter to see if there is a short.
ronv said:How do you have it hooked up now? Are you pulsing the one side of the bridge? Can you make a schematic of the motor and limit switches?
ronv said:What I was saying is that the actuator needs to be stopped before you reverse it. With the limit switches I'm thinking that will happen.
Seems to be shorted from the picture. So now measure from drain to source of each FET. They should all be open.
Measure with the probes in both directions (red on drain black on source and vice versa.
So both of the right ones are shorted. Usually that happens when both are turned on at the same time but the driver should prevent that. Any thing unusual happen?
I hate to leave now but I must go.
