WTP Pepper
Active Member
Assuming the motor is OK, buy an identical drive off ebay and swap the controller board.
Do not attempt to change the platters or heads.
Then backup.
Then backup.
I have just had my second Samsung hard drive fail on me after about 2 months - the first was a 3.5" in my main PC and this one was a 2.5" in my laptop :-( Not doing Samsung again!!! Both times they stopped spinning without warning, the lappy example gets quite warm so this is clearly a seized spindle or similar... Now I can't find the bloody receipt arghhhh!!!!
Good idea MrAl, a metal digital gramophone record Seriously, think how long vinyl records last. BBC recently played a recording that was at least 100 years old, what do we have now that can survive that long? HDDs die if not used for an extended period of time as I discovered recently when I tried to install Windows 2000 on an old 4.3GB drive, that was working a few months ago, to test some software..... use an aluminum disk as the platter. Have the CNC station (just an automatic drill press) bore tiny holes in the surface of the aluminum disk. Bore a deep hole where there is a 'zero', and a shallow hole where there is a 'one'. Store the disk in oil.
Should last for a while
Built a small mini CNC station, where you use an aluminum disk as the platter. Have the CNC station (just an automatic drill press) bore tiny holes in the surface of the aluminum disk. Bore a deep hole where there is a 'zero', and a shallow hole where there is a 'one'. Store the disk in oil.
And there's the rub. I always set CD-writers to verify the written data immediately, but after a while the data can obviously become corrupted.I've never had a CD or DVD fail unless the burn didnt work
I've never heard of that. Can't think of any physical reason why storage orientation would be important, other than avoiding warping of the CD under the weight of others not vertically aligned.Oh yeah, they have to be stored properly too, up on edge i think
Plant your hard drive at the scene of a hardcore crime. I'm sure CSI will recover all your data.
alec:
Timescope:
