#ifndef MBMC_H_INCLUDED
#define MBMC_H_INCLUDED
This program is free software: you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation, either version 3 of the License, or
(at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program. If not, see <http://www.gnu.org/licenses/>.
// defines and structures for MBMC networking
#define __MBMCAPP_H
#include "mbmc_defs.h"
#include <GenericTypeDefs.h>
typedef struct harvesttype {
LONG energy, usage, prev_energy, prev_usage, e_total, u_total;
LONG count, charger, c_total, prev_charger, diversion;
} volatile harvesttype;
typedef struct battparmtype {
WORD esr, current, voltage, ah, temp;
BYTE soc, cef, flags;
} volatile battparmtype;
struct battmodeltype {
struct battparmtype soc[MODEL_SLOTS];
typedef struct SDCARD {
WORD magic;
BYTE sdtype, sdinit, sddetect, DAYCLOCK;
DWORD sdpos, sdnext, timekeep, time;
struct harvesttype harvest;
SHORT h[H2][H9]; // battery history data
} SDCARD_TYPE;
typedef struct SD_VOLUME_INFO {
DWORD size_MB;
DWORD sector_multiply, read_block_len;
DWORD sector_count, serial;
BYTE name[SDNAME_SIZE];
} VOLUME_INFO_TYPE;
typedef struct SDDUMP {
BYTE dumping, type;
DWORD sdpos;
} SDDUMP_TYPE;
typedef struct ccstype {
BYTE pick, boi, boc, alert, bn;
} volatile ccstype;
struct portstype {
BYTE PORTB, PORTD, PORTE, PORTJ;
typedef struct diversiontype {
BYTE flag, power, control, alarm;
} volatile diversiontype;
#if defined(__18CXX)
typedef struct celltype { // C18 uses byte alignment
#else
typedef struct __attribute__((aligned(1))) celltype { // force C32 to byte alignment, 32bit alignment is still critical
#endif
WORD id,model; // battery cell type S,M,L
LONG voltage, current, charge, cycles, noload, date;
BYTE cconline, online, discharged, dead, critical, valid, fresh, misc;
float weight;
} volatile celltype;
/* hist[x].h[x]
* h0 Peukert Factor adjusted Ah usage this cycle, MUST BE INTERGER variable type!
* h1 Lowest discharge ever,
* h2 current lowest discharge,
* h3 avg discharge
* h4 Number of full charge cycles, h5 Number of full discharge cycles
* h6 Real Ah usage this cycle, MUST BE INTERGER variable type!
* h7 Min Batt Voltage
* h8 Max Batt Voltage
typedef struct histtype { // C18 uses byte alignment
#else
typedef struct __attribute__((aligned(1))) histtype { // force C32 to byte alignment, 32bit alignment is still critical
#endif
WORD peak, rate, usoc, bsoc, ce, cb, samplei, sampleo, ah, drate, esr, rrate, rfactor;
SHORT h[HPARAM_SIZE]; // h[6]=cumulative battery Ah cc and inv (real),h[0]=cumulative battery Ah cc and inv (p_adj)
LONG kwi, kwo, ttg, btest;
LONG ahi, aho, ahir, ahop, thermo; // A stored in battery, A taken from battery, A from raw pv, peukert adjusted A
LONG pv_eff, tot_eff; // pv generation eff factor, total system eff factor
float peukert, cef, peukert_adj, cef_calc, cef_save;
} volatile histtype;
typedef struct buttype {
DWORD bvi, bvo;
BYTE boc, boi;
LONG bii, bio, bil;
} volatile buttype; // battery voltage in/out, battery current in/out/load ,battery on charge, battery on inverter, battery inverter load
struct almtype {
BYTE alm_flag, alm_count;
struct almbuffertype {
BYTE alm_num, bn;
struct mbmccmdtype {
WORD ready, cmd;
struct datadefaulttype {
DWORD data_default;
struct lcdb {
CHAR b[LCDW_SIZE];
struct timeruntype {
DWORD hour, day, weeks;
struct mbmcnettype {
BYTE *mbmc_byte;
WORD mbmc_index, mbmc_len;
#define HOST_REQ '0' // request mbmc ID
#define HOST_ACK '1' // data ack code, returned when finished
#define HOST_REAL '2' // send mbmc realtime data
#define HOST_CELL '3' // send cell data stucture
#define HOST_HIST '4' // send history data structure
#define HOST_SDC0 '5' // send a SDCARD sector
#define HOST_CMD_F 'F' // send FORCEOUT command to ccvoltage controller
#define HOST_CMD_V 'V' // send charger toggle command to ccvoltage controller
#define HOST_CMD_v 'v' // send charger off command to ccvoltage controller
#define HOST_CMD_SOC '*' // send set SOC command to ccvoltage controller
#define HOST_CMD_UTC_S '6' // start xmit of UTC time to controller
#define HOST_CMD_UTC_E '7' // end xmit of UTC time to controller
#define BCRELAYS PORTE
#define IORELAYS PORTJ
#define DIPSW PORTD
#define EXTIO PORTB
#endif
// SDCARD data format structure using TypeDefs for pic32 host
typedef struct mbmcdata { // C18 uses byte alignment
#else
typedef struct __attribute__((aligned(1))) mbmcdata { // force C32 to byte alignment, 32bit alignment is still critical
#endif
LONG ccvoltage, inputvoltage, primarypower_B1, primarypower_B2, systemvoltage;
LONG currentin, current, currentload;
LONG thermo_batt, cef_boc; // cef*100
LONG PRIPOWEROK, DIPSW;
LONG pick, boi, boc, alert, bn;
LONG CHARGER_B, DIVERSION_B;
LONG MBMCID, UTC;
struct portstype ports;
struct diversiontype diversion;
// LONG crc;
} volatile mbmctype;
typedef struct mbmcchart {
struct mbmcdata data[MBMC_CHART_POINTS];
DWORD sdate, edate, start;
BYTE pos, gap;
float avg;
} mbmccharttype;
#else
#endif
typedef struct mbmcflagtype {
WORD mbmc_cmd, mbmc_data, mbmc_ack;
WORD host_cmd, host_data, host_ack;
DWORD cmd_timeout, host_timeout, data_timeout, data_len, data_pos;
BYTE rx_9bit, tx_9bit, mbmc_done, host_done, *data_ptr;
} volatile mbmcflagtype;
typedef struct mbmcstatustype {
BYTE seq;
BYTE real_valid;
BYTE cell_valid;
BYTE hist_valid;
BYTE sdco_valid;
BYTE cmd_valid;
DWORD sent;
DWORD received;
DWORD cmdsent;
DWORD cmdreceived;
DWORD acksent;
DWORD ackreceived;
} volatile mbmcstatustype;
typedef struct R_data {
long current, currentin, currentcharger, thermo_batt;
unsigned long systemvoltage, ccvoltage, inputvoltage, primarypower[POWER_SLOTS];
} volatile R_data;
typedef struct C_data {
long currentload;
int temp_drate;
float t_comp;
} volatile C_data;
typedef struct B_data {
SHORT start_ahu, cef_raw; // must be int TYPE
DWORD start_ahi, start_aho; // unsigned long TYPE
BYTE yesterday, today; // Harvest quality for the whole day, 0..100, uses time of harvest (seconds) -> input power (watts) -> max power (watts).
} volatile B_data; // of each measurement during that period.
#endif /* MBMC_H_INCLUDED */
