BGAmodz
I am bad with Digital...even my Meter is Analogue like me
All the best,
tv
I also use analog meters , specially for diode/transistors tests.
All the best,
tv
care to tell WHY specially?I also use analog meters , specially for diode/transistors tests.
care to tell WHY specially?![]()
Especially if your looking for a very short (single digit ms) voltage/current/whatever spike/dip (and can't find your 'scope).I'm with TVTech - analogue meters are still VERY useful.
An interesting fact with digital meters (at least in my experience) is testing LOPT stages in TV's - it's fed with around 100V to 150V DC, but has a 1000V flyback pulse on it when it working correctly. Using a digital meter (on the 1000V range) reads the correct DC voltage, but also lights up ALL the decimal points in the display - if there's no decimal points, then the LOPT isn't running.
Nice info nigel .
But i thought a ring tester also known as RINGER was necessary for LOPT or other SMPS transformer.
Even better, but a digital meter gives more info than you think - showing if it's running or not.
Normally if the LOPTX has shorted turns it blows the LOPT - that's where the ringer comes in (I threw mine away a few years back - no call for them now).
Lol....never used a ringer. I remember in the early 90's someone tried to sell us something like that.....tests for shorted windings and all...problem is that it does not test at actual working Voltage and stuff when things are oscillating...big difference.
It doesn't need to test at working voltages, a shorted turn is a shorted turn - and that's what it's testing for.
A forerunner of the LED and logic chips versions was using an old oscilloscope - some of those had a timebase output, and you could apply that to the LOPTX (a pulse to make it ring) and checks the ringing on the scope trace.
But neither the scope or LED version is foolproof - you need to have enough experience with different makes and models to know how they 'should' behave under a ringing test. The tester I used (which I built from a kit) had green LED's at the top (for good), red LED's at the bottom (for bad), and a fairly wide range of yellow in the middle (for - not really sure)But a few years of experience with it soon showed you what readings are good or bad on different sets.
A classic example would be a set 'clicking' (continually powering up and shutting down) - stick the tester on chassis and the collector of the LOPT, and press the button - an instant indication (with near zero effort) of the state of the LOPTX (which was a VERY common cause of such symptoms).
