thekyguy11
I attached my first attempt at a State Diagram, How does it look?
I don't think I mentioned about the Siren Output yet. I want it to warn the driver if the Prox Detector loses signal of the "KEY" (I don't even know what the device is called yet, lol) while in State 2,3, or 4. I'll have to check how the Acura TL is setup, but I know if you leave the car running and take the Key FOB out of range it sends a warning beep, then I think there is a timer for how long it will remain on, unless the FOB is brought back into range.
Also, as far as an RPM input, should I build an RPM switch that outputs a simple ON/OFF to the PIC once the right RPM is reached, or should I connect an RPM signal right into the PIC and have the program handle it? Or should I go back to my original plan to build the rpm switch and wire it to a starter cut relay?
I'm learning so much with this, and you guys have been great so far. Thanks again.
