I need someone to make me a diagram of an easy to make coin trigered motor.
If you can help i will appreciate it.
Ok i found one but can you draw a diagram and tell me what pieces i will need buy cuz im stuck.
The coin goes back up?yeah i want the motor to do 4 rotations then on a btton click it goes back up
How are you getting up and down with a motor that has a rotating drive shaft?Basicly you put a coin in it activates thee notor to turn 4 rotations then when he motor is at the bottom it stops,
after that you need to press the wind up button and the motor will do 4 rotations upwards
OK why is the motor rotating 4 times?the motor just pulls down a bison tube,
while the coin falls down and lands in a box
Can you put limit switchs on the top and bottom?all i need is some sort of timer for 4 rotations or something
