Hello i need help to finish my design of my resonant transformer it is able to multiply the voltage in by a factor of at least 100 with few windings. I'm working on a pll design that needs to be able to tune automatically to the resonance of two in one tank circuits, one parallel and one in series, formed between inductors stray capacitance and inductance and also in series with the second capacitor and one of the inductors. The point is that i need to design a feedback coil that get the resonance frequency signal and transform it to 50% duty cycle square wave to use it to lock the 4046.
I need help thus with the figure 9,8, and 7. Figure 7 is the pll 4006 i think on the left and 4001 on the lower part this part of the circuit i have already working-+, Figure 9 is the feedback signal it needs an op amp i don't know witch. and resistors value. i bough a lm393 tried to wire like that and didn't work i used 500 ohms on the feedback prior to diodes and resistors value i tried with 50k 1k here and there. hope some one can help me please. This circuit is made for extract electrons from the air and reuse them as a source of energy by creating a second even higher voltage connected in series with it thus a flow for that available current source.
Thank you
Thank you
