help negative voltage
japl
hi
what is the easiest way (small circuit) to produce a negative voltage for a op-amp -VEE. the input would be a positive voltage say +12V to -12V.
thnxs for the help
japl said:
hi
thnxs for the help
Unfortunately, the ICL7660 is only rated at 10V, so that's prevents that been used :cry:
At a quick glance, I couldn't find a higher voltage version, but there may be one?.
Maxim give a design for doing this at **broken link removed**, but it looks rather complicated.
just order in a DCDC converter. Newport do some very small (in size) dual output SIL modules.
Check out (these are british)
rswww.com
www.farnell.com
farnell deliver to the public, RS dont like to
negative voltage
You could use a Linear Technology LT1054CN8 they are good to an input voltage of 15V. Digikey stocks them.
i assume you are starting with a positive supply? if so, something along the lines of the following could be used... this creates a "floating ground"
of course, this contains an extra LED and Resistor to tell if it's powered, and the overall circuit will need to be slightly modified to accomidate 12 volts.
That will only work if the load draws equal amount of current on both the negative and positive side
Look for a charge pump IC. You should be able to find one that will give you a negative voltage equal to the positive voltage input.
plot - I don't think you can assume that OpAmps draw the same current from both rails. For example: an opamp driving 25mA into a load will be drawing those 25ma from the positive rail.
Brent
