help PCB probelm
cannibal
Hello
I have circuit which was working perfect in the breadboard
the circuit is attached like it is when was working
when I made PCB and moved all the parts
the buzzer is making non stop sound
I don't know where is the problem
could you please check my pcb to see if I made some connection wrong !!
I checked the soldring and nothing touchs
please help
If the transistors are BC337 then the pcb for the 555 and transistors is the same as the schematic.
Like I said in the thread about this circuit, the 555 will never time out if one LDR is in the dark. Then the buzzer won't stop.
The pin 2 trigger pin of the 555 must be pulsed through a coupling capacitor then pulled up with a resistor to correct it.
yes that feature is needed
(the 555 won't time out if one LDR is in the dark)
if the PCB is correct why you think the buzzer won't stop
like in the breadboard ??!!
do I have to replace the 555 or the transistors ??!!
I was double chacking the circuit
and I found that
R4 is brown black yellow
it should be 100K
but in multimeter it shows only 9K
do you think that R4 is the problem that maks buzzer not stoping ?!
it should be 100K
A very bright light (sunlight?) might be needed to overcome the 9k resistor to turn off its transistor.
it should be 100K
You can't accurately measure R4 in circuit. Disconnect at least one end of R4 first before ohm metering it.
