Help Required For Tachometer Circuit...
I am trying to build a tachometer using IR Sensors..
I get good response at lower frequencies but as the frequency increases say to 170Hz it looses the wave..
i am using a hysteresis resistor of 1M at positive feedback and input is at inverting terminal of op-amp should i use hysteresis resistor i think the problem is with this as the frequency increases..
and if i remove the resistor response is so fast and ir sensor is imune to even little jerks..
Plz Someone give expert opinion.
Thanks In Advance
Which IR sensor are you using? Can you post a link to its datasheet?
