djsfantasi
A couple of responses have indicated that such a small vacuum cleaner would be only able to suck dust and bread crumbs. But that is exactly what the OP said was the requirement - to be able to pick up bread crumbs.
A little searching suggests that the following battery is compatible with this motor: ParkZone 1S Li-Poly Micro 14C Battery (3.7V/120mAh) [PKZ1035] | RC Airplanes - A Main Hobbies
The size of the battery is:
Length: 1.325 in (33.7mm)
Width: 0.440 in (11.2mm)
Height: 0.220 in (5.59mm
I am curious how the OP plans on building the mechanics... Good luck!
