Hi ,
I'm using a infrared LED pulsing at 38kHz and a TSOP1738 receiver to receive the signal from the LED.
I have checked the transmitter through an o'scope and it seems to be pulsing at 38kHz with ~50% duty cycle.
The IR LED is being driven by a BD139 with on current = 100ma.
The TSOP1738 responds to pulses from the TV remote and i can see the pulses on the o'scope.
But , when i turn on the Ir transmitter , the output of the TSOP goes low for around 1.5s , then goes high again. This is happening from atleast 10 feet.
(which is more than enough range for me)
I understand that this is due to the gain suppression by the TSOP when it detects a continuous signal to reduce noise.
How do i make a circuit such that the output of the TSOP is continuously low , when the the IR LED is pulsing and it is continuously high when it is not pulsing.
I dont want to use and nor am i very comfortable with programming microcontrollers. I want to finish this with using only ICs and transistors.
I read the datasheet but did not understand much about the transmission protocol.
Should we first send our data in less than 70 cycles of 38kHz ?
then should we wait for 4 times long? (70*4 = 280 cycles)
all this is getting pretty confusing for me...
can sum1 please explain how the TSOP expects the IR light to be modulated and show a simple circuit that demonstrates how to do this?
![Confused :confused: :confused:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
