I've got the chip all set but every time I power up the amp. I get a hum through the speakers but no guitar sound. I checked for continuity as well but nothing by hum...
You need to check for high dc at the speaker out put end the amp will power up with no speaker connected... Question did you just fit the ic and power on?. Use a 10 ohm 10 watt resistor instead of the speaker.
Check the supply voltages, preamp voltage would be 15 plus and minus and the rear amp supply would be say 18 to 22 plus and minus v.
The speaker output voltage will be in mv volts..
Try not to just change parts at will as your waste time and parts.. Check the small opamp ics in the preamp circuit.
Marshall..park.. Fender small type amps are more or less the same..
