yes, I've told in post #14.as he's in Ipoh, relatively far from my state, JB. So I suggested he get it through Farnell. much better anyway, they're cheaper.
The same concept applies, I think... (What do you think, Sir Eric?). A short circuit between the terminals mean you are hitting the drum. The same thing can be achieved using the previous circuits, one terminal goes to the ground, the other to the output, regarding your green PCB terminals.
higot any solution..???
i want to use easy pcb for beginner...any sugestion...my electronic source right now is from **broken link removed** and **broken link removed** u help me seacrh for suitable PCB from this two site..
mmm.. I'll take that if I were you since I'm not informed about stores in Ipoh. In KL, Jalan Pasar is the place to get these things at cheap prices. If you're dropping by KL anytime, which is only 3 hours, right? You can get them and haggle the prices as well. A Veroboard of that size in Nixie Electronics is around RM3.50. Much cheaper.
Jalan Pasar. Remember that.
Eric, what program did you use to make that PCB diagram? Did you create that sw? Name it VarotraKPretty cool.
hi sky,
Look at these images, use the PCB layout, CHECK it carefully.![]()
