BTW, if bose is bad, which is best/good?
Actually, I am wondering where the subwoofer signal would come from. It will be fed through the existing amp I have along with the left and right channel(?) which is around 40W.The sub-woofer controller uses a 15 inches sub-woofer speaker being driven from a 400 Watts amplifier. Maybe your sub-woofer speaker is not that big and can't handle that much power. The controller boosts the low frequencies because the enclosure for the sub-woofer is too small for a regular woofer.
I agree but I don't have the heart to dump it either.I think your speakers from an old radio-cassette player will be cheap garbage.
The signal to the subwoofer controller should be after the volume control of the amplifier. Usually the "tape output" of an amplifier is not adjusted with the volume control so it cannot be used.Actually, I am wondering where the subwoofer signal would come from. It will be fed through the existing amp I have along with the left and right channel(?) which is around 40W.
