so the changes will be...
for the ECC83 one more resistor 47K before the 100K and between them a 22uF/400V decoupling capacitor.
That sounds something like.
for the EL84 a 2k2 resistor for the screen which i think it's the recomended value for the EL84... and a bigger value for the cathode probably 150ohm/4W
Go for it.
Changing the cathode resistor is essentially changing the negative bias voltage on the grid - for really high power amps you normally supply a negative bias, which will usually be adjustable, in order to get maximum power from it. For a small amp cathode biasing is beter, and it's self adjusting.
if i'm not wrong... EL84 must decipate 12W so i'm going to measure the voltage between anode-cathode and the current the tube draws so i can regulate it... is that ok or i'm still obsessed?
i just don't want to destroy something which it isn't as cheap and also it's not so easy to find as a simple transistor![]()
The PSU voltage probably won't change a great deal, particularly with using a semiconductor bridge rectifier, and a much larger electrolytic - original valve amps would be a half wave valve rectifier, and a 16uF or so. Guitarists still like to use that configuration, as the supply sagging excessively adds to the distortion.
btw my output tube has also a blue glow... and it's very nice!and as far
as i know that can happen with high rush of electrons hitting things inside the tube and releasing photons.
I never like to see valves with a blue glow.
