help wif project sourcecode
Desperrado
Im one day away from my deadline and my project isnt working!!i realli nid help.I have connected a Cygnal C8051F005 to a farnell lcd.My connections are : LCD pin 7 to 14 to c8051 port 1(p1.6 to p 1.1) and i nid to show the words " Height : " without the quotes.The lcd still cant work after i inputted the program.here is my program.Pls correct my program.The datasheet for the lcd is **broken link removed** reply to [email protected].I really appreciate any help at all and many thanks to those reading the post.
#include<c8051f000.h>
sbit E =P0^4;
sbit RS =P0^6;
sbit RW =P0^7;
void delay(unsigned a,unsigned b)
TMOD = 0x01;
TR0 = 0;
TF0 = 0;
TH0 = a;
TL0 = b;
TR0 = 1;
while(TF0==1);
void delay_1()
int a;
TMOD = 0x01; // Timer Mode Register
for(a=0;a<50;a++)
TH0 = 0x00; // Timer 0 High Byte
TL0 = 0x00; // Timer 0 Low Byte
TF0 = 0;
TR0 = 1;
while(TF0==0)
TR0 = 0;
void delay_2(unsigned int x)
while(x!=0)
x--;
void strobe()
E = 1;
delay(0xFF,0x69);
E = 0;
delay(0xFF,0x69);
void data_write(unsigned char x)
RS = 0;
RW = 0;
P1 = x;
strobe();
void control_write(unsigned char x)
RS = 1;
RW = 0;
P1 = x;
strobe();
void display_init()
XBR0 = 0x00;
XBR1 = 0x00;
XBR2 = 0x40;
PRT1CF=0xFF;
PRT0CF=0xFF;
delay(0x8A,0x00);
RS = 0;
RW = 0;
P1 = 0x38;
strobe();
delay(0xFF,0x00);
RS = 0;
RW = 0;
P1 = 0x0E;
strobe();
delay(0xFF,0x00);
RS = 0;
RW = 0;
P1 = 0x01;
strobe();
delay(0xFA,0x00);
RS = 0;
RW = 0;
P1 = 0x06;
strobe();
void main()
display_init();
control_write(0x80);
data_write(0x48);
delay(0xFF,0x00);
i see atleast two inconsistencies
TMOD = 0x01;
TR0 = 0;
TF0 = 0;
TH0 = a;
TL0 = b;
TR0 = 1;
[b]while(TF0==1); [/b]
shouldn't it be :- while(TF0==0) . ?
then
void delay_1()
int a;
for(a=0;a<50;a++)
TF0 = 0;
TR0 = 1;
[b]
while(TF0==0)
 TR0 = 0;
[/b]
the bolded part resets the the timer in the first loop itself. right.?
i think it should be
for(a=0;a<50;a++)
 while(TF0==0);
 TR0 = 0;
the lcd still cant work after i changed according to your help,and
data_write(0x48) is supposed to display the lettere "H"..i thought ill start wif something small at least get the lcd to display a letter 1st.however the lcd jus keep jumping..meaning the lcd's 1st row & 3th row(from top to bottom) keep jumping to all 4 rows,all the while displaying full dark characters on each row.
ill elaborate the lcd screen -> XXXXXXXXXX
XXXXXXXXXX
Then in will changed to -> XXXXXXXXXX
XXXXXXXXXX
XXXXXXXXXX
XXXXXXXXXX
sorry its supposed to be XXXXX<-1st row
XXXXX<-3th row
then the lcd will change to XXXXX <-1st row
XXXXX <-2nd row
XXXXX <- 3th row
XXXXX <-4th row
n the parts of my program that are changed ->
TMOD = 0x01;
TR0 = 0;
TF0 = 0;
TH0 = a;
TL0 = b;
TR0 = 1;
while(TF0==0);
void delay_1()
int a;
for(a=0;a<50;a++)
TF0 = 0;
TR0 = 1;
while(TF0==0);
TR0 = 0;
I hope i got what you are teaching .
P.S the lcd still retains the "jumping"
XXXXXXXXXX
XXXXXXXXXX
XXXXXXXXXX
XXXXXXXXXX
ok.two more ..in the display_init()
modify
[b]RS = 1;[/b]
RW = 0;
P1 = 0x38;
strobe();
delay(0xFF,0x00);
[b]RS = 1;[/b]
RW = 0;
P1 = 0x0E;
strobe();
delay(0xFF,0x00);
[b]RS = 1;[/b]
RW = 0;
P1 = 0x01;
strobe();
delay(0xFA,0x00);
[b]RS = 1;[/b]
RW = 0;
P1 = 0x06;
strobe();
and the strobe fn:
void strobe()
[b]
E=0 ;
delay(0xFF,0x69);
[/b]
E = 1;
delay(0xFF,0x69);
E = 0;
delay(0xFF,0x69);
and main as
void main()
display_init();
data_write(0x48);
delay(0xFF,0x00);
[b] while(1); [/b]
i have changed the parts that u advise me to change now my program is
void display_init()
XBR0 = 0x00;
XBR1 = 0x00;
XBR2 = 0x40;
PRT1CF=0xFF;
PRT0CF=0xFF;
delay(0x8A,0x00);
RS = 1;
RW = 0;
P1 = 0x38;
strobe();
delay(0xFF,0x00);
RS = 1;
RW = 0;
P1 = 0x0E;
strobe();
delay(0xFF,0x00);
RS = 1;
RW = 0;
P1 = 0x01;
strobe();
delay(0xFA,0x00);
RS = 1;
RW = 0;
P1 = 0x06;
strobe();
and
void strobe()
E = 0;
delay(0xFF,0x69);
E = 1;
delay(0xFF,0x69);
E = 0;
delay(0xFF,0x69);
plus
void main()
display_init();
data_write(0x48);
data_write(0x47);
data_write(0x45);
data_write(0x48);
data_write(0x48);
while(1);
however the lcd stills retain its "jumping"
