hello people...
recently i was working with an AD620 instrumentation amplifier... it has a gain range of 1 to 1000.... tis gain can be varied by an external resistor connected between pins 1 and 8 of AD620....
gain = 49.4k/(Rg) + 1... where Rg is the resistor between pins 1 and 8...
i used two AD620s... the first one was set for a gain of 1000 followed by the next which was set for a gain of 100 by selecting appropriate resistors such that the above relation is satisfied.... the output of the first AD620 was fed into the input (pin3) of the second AD620 and its other input (pin2) was grounded... the AD620 was supplied with +/-12V
the input to the first AD620 was a 20mV 71 Hz square pulse... with the setup above the output must have saturated to 12V rite (20mV*1000*100) ??? But i observed just a 2.4V output....
Why is this happening? Is the procedure correct? Pls help...
Thanks in advance...![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
