hello,
I've done a couple of atx psu conversions before but my current one has thrown up a problem that I've never seen before:-
I started with a psu that was 'new' but had a tendency to go into oscillation (squawking) under load so maybe that was asking for trouble.
I was looking at the output from the transformer on the 'scope when it was under a small load and was running stable (nearly silent) and noticed something odd: the amplitude of the output modified square wave is about 20% higher for one half of the cycle than the other.
My first guess was a dodgy rectifier but they all seem to be OK.
Then I thought: maybe a short on one rectifier outout - but no.
Then I checked the voltages on the primary side capacitors - thinking one might be at a lower voltage than the other for some reason: 165v and 166v - not enough I think to explain a 20% difference in amplitude on the secondary side though.
so now I'm stuck - I can't see what would cause the difference in amplitude given that the transformer is driven via a capacitor anyway, other than an asymmetric load/rectifier problem which I'm thinking I've ruled out.
Anyone got any ideas of possible causes? Or seen this sort of problem?
Apologies for the lack of schematic & scope traces but I do them on paper and getting pics from my ancient camera into the PC is very cumbersome. If needed I can do it but it's likely to take me a day or so
the mod is basically to get 28v out so I'm full wave rectifying the '12v' outputs of the transformer to give + & - 14 v; the 5v outputs have been removed, and the torroidal inductor has been rewound with two matched & opposed windings, if that helps.
thx
thx
