as u guys see in the schematic I would like to powering the electret microphone
and connected to mic pre amps, and the mic pre amp has input impedance of 47 Kohm,
because the microphone has XLR connector, I connect the pin 2 in series with c1 before it goes to input of pre amp;
my question is if i put 6.8uF capacitor in series, would it be high pass filter? because the input impedance of mic pre amp (m040 pre amp) 47k, so the cut off frequency will be 0.5 Hz?
will it be ok? because the Frequency range of pre amp: approx. 10 Hz...100 kHz
do i have to use same value of capacitor for pin 3?
thanks..
thanks..
