combatwombat_nz
Hi guys... I'm first timer with this stuff, and new to this forum, but have enough electronics knowledge to be dangerous (used to fix slide projectors and such, now fix computers for a living)... anyhow, down to the question:
Wifey bought a treadmill secondhand. No manual. No data sheets. No go. My job is to fix it.
It is a Sportrack Treadmill, apparently out of China. I am in NZ on 240V, and this is a 240V device. Upon turning on, it shows a Dist reading of 2.5, then E2 in the error register, and "KM" in the main led screen.
It runs with a Power Conversion/Control board, that takes the AC down to DC for the User Control board, and DC for the Treadmill motor, and branches out with AC for the Incliner motor.
The problem appears to be the DC driving the Treadmill motor. The motor has the following on it's label:
Catalog A1D061. HP:2. RPM: 4000. Volts: 180. Amp: 8.5.
The output from the PCB to the motor is DC 140V constant from power on. Tested with digital multimeter.
So, is the voltage supposed to be higher, ie 180V, or will it go higher when then machine is set into motion? Or is the motor toast, as I thought it should have responded to an input of 140V? Surely the POST diagnostics of the system should do a quick check of the motor, and it's ability to respond - therefore why does the voltage stay at 140V with this error message, rather than going up there, then coming back down?
Or am I barking up the wrong tree?
TIA
TIA
