Start at the beginning.
It would be good if you cited a source showing land plants prefer CO2 in liquid form. In the meantime, here is a link that shows how leaves inhale CO2 and exhale O2 through their leaf stomata
https://simple.wikipedia.org/wiki/Stomata . You are ignorant of the fact that the warming oceans are releasing CO2, not accepting it. The increase of CO2 is largly caused by the Earth's warming, not man made causes. Warmer water does not hold as much CO2 as cold water does. That includes vast amounts of vegetative impregnated land (peat) in Siberia and other northern land masses.
What solar influence? Ozone protects from UV radiation. What does ozone have to do with CO2?
I never mentioned where CO2 comes from. I said that CO2 is swamped by a more insulating gas, specifically water vapor. Other gases like methane are more potent but much more scarce.
What does the above paragraph have to do with the cause of climate change? What does the food chain have to do with climate change?
Cutting back on CO2 emissions will not help for the reasons already stated. The small amount of CO2 in the air is not causing global warming. If you can control the solar cycle, and reduce the amount of solar wind emanating from the Sun, then you could do it. But, be careful of unintended consequences. Fortunately, I don't know of any mortal being who can do that.
You have to know why before you can know how. The right thing to do is to not try to change things for the purpose of climate change. Instead, just cope with what is happening, while knowing that you cannot change global warming. Global warming is not necessarily bad. After all, we would not want most of the northern hemisphere covered in a glacier, would we?
Ratch
Not a good topic to pick me up on.... I know how transporation works thanks, the problem with it is the stomata have to be open and that requires a fairly narrow band of humidity and temperature. As for bio availability via leaf or root..... Take your pick of studies, but before i supply one consider the following.
Many aquarium keepers add CO2 to the aquarium, it forms carbonic acid, most the plants in the aquarium are actually bog plants. While not really designed to live submerged all the time, they do ok mostly.
Your reference regarding leaf and root preference
https://onlinelibrary.wiley.com/doi/full/10.1111/j.1399-3054.1971.tb01436.x
This one a bit tricky, it looked at inhibitors to CO2 up[take in roots, but does give you the mechanisms. Note all these methods work even when stomata of leaves are closed like say in very hot conditions.
https://link.springer.com/article/10.1007/BF01394749
Interesting one on rice and Co2 root uptake, note rice is one the few plants to take it up as a gas at root level, its also a transport oddball.
https://www.tandfonline.com/doi/abs/10.1080/00380768.1982.10432389
This one the abstract is a bit misleading, if you want to read the whole thing shout me, but in a nutshell.......CO2 uptake by roots in willow trees makes then grow much faster than via leaves, its also more common than previously known..
https://onlinelibrary.wiley.com/doi/abs/10.1111/j.1365-3040.1985.tb01689.x
Right so thats the first one squashed i think you would agree?
Ermm not sure how to answer this, its alot like asking what has water got to do with getting wet! I dont know but maybe you should start here
https://www.sciencedirect.com/science/article/pii/0269749189901668
Or try wikipedia, many people are more comfortable with wikipedia than scientific journals, its not always as accurate but it might ease you in a bit.
The role of CO2 directly affecting Ozone is via coupled reaction with mainly HCFL gases and anything with a Chlorine hanging off the molecule, getting a non book ref is a bit harder and they are pay walled, I will come back with a mechanistic reference showing how CO2 is not only a green house gas but actually enhances depletion of Ozone (not the same thing!)..
Erm as the above papers show, CO2 and water or water vapor produce Carbonic acid, water vapor actually helps solvate the process. Mitchell 1979 as ref, seeing as you havnt referenced anything but wikipedia i am less inclined to look for decent surces for you, when you return comment use a decent peer reviewed source please.
Direcctly nothing, indirectly everything, 40 years ago or whenever they planned the barrier, was done because of 'new at the time' research into climate change, the basic models even then showed that increases in certain gases would lead to a warming and rising of sea levels.....Not sure if you really dont get what was written or are simply trolling here.
I kind of argued against CO2 being the main focus myself, but to suggest the only way is solar wind......How about increasing or replacing the natural carbon sinks like rain forest?? Or you seriously telling me solar winds are the main problem and we are doomed whatever we do??? If so its time to go by some tinfoil.
Just cope with it, not really a bad thing.......
Ok i want a decent reference for that please. or go sit with the OU guys
